Conference
V.Naveen Kumar
How to configure Conference in CUBE
Give sample configurtion
6 Replies 6
ronpatel
Level 8
Level 8
You need DSP resources on the CUBE router.
Below link shows you the sample config
http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/interop/intcnf2.html
regards
Ronak Patel
Rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
after configuring with CUBE and how to integrate with CUCM
You can host transcoding resources internally on the CUBE without integratiing with CUCM. Here is a link on how to configure it.
http://www.cisco.com/en/US/products/sw/voicesw/ps5640/products_configuration_example09186a008092d6b3.shtml
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
hi aokanlawon.
still i am confused in configuration of conference..
#dspfarm profile 10 confere
#desc
#codec XX
#maximum confbr 2
#assoc sccp
#exit
#gateway
#rtp-timer 1200
#exit
#conf t
#sccp ccm group xx
#assciate XX priority 3
#asso profile 10 register cfb123
#bind intf (IP addr of CUCM)
#exit
IN CUCM
type ++>>confernce hardware
device pool  XX
exit
conference bridge status is up in CUBE
Conference bridge is registered with call manager
But Still i m  not able to make conference call.
for ex: if tried add other site person into conference call ==> call gets failed
Is their configuration missed out..
Plz suggest me
Why it is failing can be due to number of issues.  The phone should have access to conference resources. In order to do this. You will have to assign the Conference resources in same device pool as the ip phones to make confeence call complete. Also assign these Conference resources in MRG/MRGl for proper utilisation.
regards
Ronak Patel
rate helpful posts
Can you send a show sccp and a sh run of your gateway.
What does the status of the conference bridge show in cucm
Also have you assigned the CFB to a MRG and the MRG to a MRGL. YOu then ned to assign the MRGL to the phones
