Config file error is the error message what to do?
sanjaydevan
Deva
Nadeem Ahmed
Hello Devan
Where do you see this error message ?
Br, Nadeem Please rate all useful post.
On the phone.
Have restarted it. Still gets the message.
You need to mention what you're using (CUCM/CME/version), and on this case, the phone model, asking for assistance just mentioning the problem, but not what you have, just doesn't work.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
