05-10-2012 10:23 AM - edited 03-16-2019 11:06 AM
I need to configure a side car ( expansion module ) in CME . can anyone please tell me the configuration commands for the same . this is my current config .
ephone-dn 168 dual-line
number 0152
label rrrrrr x0760
description rrrrrr
name rrrrrrrrr
mobility
snr calling-number local
call-forward busy 0799
call-forward noan 0799 timeout 32
ephone 10
device-security-mode none
description rrrrrrrr
mac-address D0C2.8243.3C6F
ephone-template 12
username "rrrr" password hhhhhh
type 7962
button 1:168
Thanks in advance
KS
05-10-2012 10:32 AM
type 7962 addon 1 ?
follow above cmd and I hope you can figure out
05-10-2012 01:34 PM
No this is not working.
05-10-2012 02:06 PM
Try this in ephone 10
type 7962 addon 1 7914
(7914 is the model number so it could be 7915 or 7916)
Hope this helps.
05-11-2012 02:35 PM
Thanks it works fine .. Cheers !!!
