Configuration File Encryption in CUCM
shinas
I am having CUCM 11.5.1.10000-6 and Phones are 8841 model IP Phone. Will this phone model supports Configuration File Encryption in this CUCM version?
Shinas
5 Replies 5
Dennis Mink
check this
https://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/118929-technote-cucm-00.html
no need to put cluster in mixed mode
Please remember to rate useful posts, by clicking on the stars below.
George Sotiropoulos
Yes, configuration file encryption is possible.
You may check the Security Guide (This is for 11.5) https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/security/11_5_1/secugd/CUCM_BK_SEE2CFE1_00_cucm-security-guide-1151/CUCM_BK_SEE2CFE1_00_cucm-security-guide-1151_chapter_01011.html
George
Hope the above helps,
gsotirop
Hi George,
But I cannot see 8841 Phone in the document for CUCM 11.5. But I can see it in Security Guide for CUCM 12.0. So, Should I upgrade the call manager version?
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/security/12_0_1/secugd/cucm_b_cucm-security-guide-1201/cucm_b_cucm-security-guide-1201_chapter_01011.html
Jaime Valencia
Have you not looked at your server to find out if the option is included for that model or not??
java
if this helps, please rate
