Configuration VLANs - VG 310
MARIO PAIVA
Hi all
I'm facing some dificulties in configuration of VLANs within the VG310
So instance I can't even view which vlans are.
Router#sh vtp status
VTP Version                     :                     2
Configuration Revision          :                3
Maximum VLANs supported locally :    20
Number of existing VLANs        :            7
VTP Operating Mode              : Server
VTP Domain Name                 :
VTP Pruning Mode                : Disabled
VTP V2 Mode                     : Disabled
VTP Traps Generation            : Disabled
Thanks in advance for your cooperation
MPaiva
kaushik_2416
In order to view your vlan details try 'show vlan brief'.
If I understood your question wrong please let me know what else is your problem I will try to get solution for it if I am able to.
