No dial tone with VIC3-2FXS/DID on cisco 2901
paolonova
Hi all,
I am trying to connect an analogue phone to my Cisco router through a VIC3-2FXS card plugged on slot 3. Router runs Version 15.4(3)M3, RELEASE SOFTWARE (fc2).
I have tried a couple of different phones but I cannot get any dial tone.
Here my conf
#sh run
voice-port 0/3/0
 ring cadence pattern01
 cptone GB
 caller-id enable
dial-peer voice 1001 pots
 destination-pattern 1001
 fax rate disable
 port 0/3/0
#sh voice port sum
                                           IN       OUT
PORT            CH   SIG-TYPE   ADMIN OPER STATUS   STATUS   EC
0/0/0           1   bri-voice   up    dorm none     none     y
0/0/0           2   bri-voice   up    dorm none     none     y
0/0/1           1   bri-voice   up    dorm none     none     y
0/0/1           2   bri-voice   up    dorm none     none     y
0/3/0           --  fxs-ls      up    dorm on-hook  idle     y
0/3/1           --  fxs-ls      up    dorm on-hook  idle     y
Any idea?
Thank you very much
Are you sure that the pin out on the phones match the FXS ports?
For more information about this see this url, http://www.cisco.com/c/en/us/support/docs/voice/analog-signaling-e-m-did-fxs-fxo/7938-2fxs-vic.html#info
Response Signature
7 Replies 7
Manish Gogna
Please try the suggestions in the following links
https://supportforums.cisco.com/discussion/12037001/no-dial-tone-fxs-cisco-2911
http://www.cisco.com/c/en/us/support/docs/voice/h323/22372-no-dialtone.html
Manish
Hi Manish,
many thanks for your reply
I checked the links provided. I am not using STCAPP. As you seen before, If I do show voice-port summary, I see the port in on-hook state. However, if i lift the receiver it doesn't change the state it remains in on-hook and there is no dial-tone; I've reinserted the voice module card in and swapped the slots without any joy.
I also have a couple of IP phones (7821) connected on the router and they are both working ok.
This is the output of
#sh voice dsp
 *DSP VOICE CHANNELS*
CURR STATE : (busy)inuse (b-out)busy out (bpend)busyout pending
LEGEND     : (bad)bad    (shut)shutdown  (dpend)download pending
DSP    DSP                 DSPWARE CURR  BOOT                         PAK   TX/RX
TYPE   NUM CH CODEC        VERSION STATE STATE   RST AI VOICEPORT TS ABRT PACK COUNT
                           *DSP SIGNALING CHANNELS*
SP2600 001 05 {flex}        37.3.6 alloc idle      0  0 0/3/0     02    0        152/0
SP2600 001 06 {flex}        37.3.6 alloc idle      0  0 0/3/1     02    0         56/0
On the second link, how can I check on IOS if I have the feature IP Plus or Enterprise Plus?
Thank you
can you please post the output of below command
#show voice dsp group all
#show voice dsp error
enable the below debug and shut and no shut the port, go off-hook and see the behavior. if still same collect the debug post the same.
debug voice vtsp all
debug vpm signal
Br,
Nadeem
Br, Nadeem Please rate all useful post.
Hi all and thank you for you help
I've tried a couple of different RJ-11 cables working on other phones. The led on the back of the router doesn't lite up.
Nadeem, i turned on debug you asked and sh+no sh the port + off hook but nothing comes up.
Here's the commands output for
#sh voice dsp group all
#sh voice dsp  error
#sh diag
#sh ver
Thank you
Hi Paolo.
Please look at the led near the port.
Does the led lite up when you go off hook?
Please post the output of a show diag and show ver.
Please provide also logs as Nadeem requested.
Carlo
Please rate all helpful posts "The more you help the more you learn"
Response Signature
paolonova
Hi all,
I brought in a tester and I found out that I have +44V. I plugged in a adapter with pins splitter and I check pin by pin. Using an adaptor, going from RJ-11 to RJ-45 back to the analogue phone I have my dial tone and telephony is working ok. I'll make a suitable RJ-11 cable.
Thank you guys for your help.
