Configure CCM 6 to send config changes to Syslog?
Caue W
Hi!
Is it possible to configure Cisco Call Manager 6 to send messages to a Syslog server when someone changes it´s configuration ?!
If so, is there any guides or configuration example available?
Thanks!
Jaime Valencia
No it's not possible.
Depending on your exact version you need to review either role based logs or tomcat logs, there are plenty of posts on the topic on CSC.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
