Configure Cisco to automatically answer Fax calls
ElwinMkanyika
Hi guys!
Is it possible to configure cisco so as to answer Fax calls automatically or is this done from the fax end ? Here are my current configurations.
voice-port 0/0/0
input gain -6
output attenuation 5
cptone RU
timeouts call-disconnect 2
description FAX_109
station-id name FAX_109
dial-peer voice 1 pots
corlist incoming In810
description Fax109
destination-pattern 109
port 0/0/0
no register e164
Rob Huffman
Hi Elwin,
This is generally set on the Fax machine itself under a config
like "Rings to Answer". Here is an example
https://h10025.www1.hp.com/ewfrf/wc/document?docname=c01363811&cc=ca&destPage=document〈=en&lc=en&product=3758394&tmp_docname=c01363811
Cheers!
Rob
"Spend your life waiting,
for a moment that just don't come,
Well, don't waste your time waiting"
-Springsteen
Thanks Rob. Finally set the fax on automatic
Faith
