configure e1 lines using mgcp service
fheya_g.ramos1
hi,
really  sorry for asking but i am new to this. How do we configure e1 lines using mgcp service? what other interfaces should i configure to make it work?
Vivek Batra
https://supportforums.cisco.com/document/90521/mgcp-gateway-integration-cucm-and-pstn-service-provider
http://www.cisco.com/c/en/us/support/docs/voice/media-gateway-control-protocol-mgcp/23966-mgcp-pri-cm.html
- Vivek
hi, Do i also have to configure translation rule and dial peer so we can use IDD, NDD, and local calls and mobile calls?
With MGCP, all digit manipulation and call routing decision happens in CUCM. You can not use dial peers and translations at gateway level when using MGCP.
- Vivek
Jaime Valencia
You can find plenty of info if you simply google MGCP configuration or MGCP example
http://docwiki.cisco.com/wiki/Voice_Gateways_FAQ#How_to_configure_an_IOS_MGCP_GW.3F.3F
java
if this helps, please rate
