Configure features button of 6911 IP Phones on CME 9
Hello, I am Amadou Dia CCNA Voice.
I  had a cisco telephony project to deploy in 3 sites (One CME 2911 and  two CME 2901). I did the deployment correctly, now my problem is that i  have many 6911 IP Phones in the deployment and  i would like to know how  to configure the button of function  (pickup, meet me and others).
Can anyone help me please? it is urgent.
Cordialy,
Amadou Daouda DIA
Manish Prasad
Level 5
Level 5
You need to configure ephone-template to achive this.
Check the above link shared by Kevin.
Here is example from the doc...
enable
configure terminal
ephone-template template-tag
softkeys connected {[Acct] [ConfList] [Confrn] [Endcall] [Flash] [HLog] [Hold] [Join] [LiveRcd] [Park] [RmLstC] [Select] [TrnsfVM] [Trnsfer]}
softkeys hold {[Join] [Newcall] [Resume] [Select]}
softkeys idle {[Cfwdall] [ConfList] [Dnd] [Gpickup] [HLog] [Join] [Login] [Newcall] [Pickup] [Redial] [RmLstC]}
softkeys seized {[CallBack] [Cfwdall] [Endcall] [Gpickup] [HLog] [MeetMe] [Pickup] [Redial]}
exit
ephone phone-tag
end
5 Replies 5
Kevin Monteiro
Level 7
Level 7
Here is a link for your reference:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeconf.html
Kindly rate the post accordingly.
Kevin
Sent from Cisco Technical Support Android App
Manish Prasad
Level 5
Level 5
enable
configure terminal
exit
ephone phone-tag
end
Hello Kevin and Manish thanks for the answer i will test it and back to you the result. Thank you again
Hello Kevin and Manish i have done by using the features-button on config template mode thanks for help.
#ephone-template template-tag
#feature-button 2 Pickup
#ephone 1
Thank you for the update and if you question is answered , then mark it as answered and rate all the useful posts.
Manish
