Configure Key Expansion Module on 8831 with SIP / Asterisk
aeciolemos
Hi guys,
A customer has just sent me a few Cisco CP8831 conferece phones to configure to use with his Asterisk-based IPPBX. He has also sent a few Key Expansion Modules along with them and I am just wondering how they are configured. Do I put special keys in the SEP<MAC.cnf.xml file or is there an external XML configuretion file I need to add? Can someone point me in the right direction or send me an example configuration?
Thank you very much for your help.
Kind regards
Aecio
Jonathan Schulenberg
The 8831 does not support KEMs.
George Sotiropoulos
Do you refer on adding KEM on a certain device, other than CP-8831, if yes what type?
Definitely, Open Speaker Phones do not support expansion modules.
George
Hope the above helps,
gsotirop
