Showing results forĀ
Search instead forĀ
Did you mean:Ā
Configured an FXS port on a router C2951, attached bud set and inbound and outbound work on a bud set (NO DIAL TONE) BUT, not a fax machine
Adrian Otey
I make test calls with the phone plugged into the port, but there is no dial tone.
You call the port it rings and answers, but when you connect a fax it is getting a dial tone error.
The other 3 ports are not configured but they can make outbound faxes and have a dial tone, but they cannot except inbound faxes.
The port I configured can accept inbound faxes, but cannot make outbound faxes, since there is not dial tone, the fax machine gets the dial tone error.
Is there a command that I am missing:
Do I need to apply a outbound dial peer?  (If inbound and outbound are working on a bud set, I should not have to.)
Is there a command to turn on the dial tone that I am missing.
I originally put groundstart on the port then changed it to loopstart, could that be the issue?
voice-port 0/2/0
shutdown
signal loopstart
echo-cancel enable
no shut
description **Fax Machine**
caller-id enable
station-id number 508XXXXXXX
station-id name XXX_Fax_Machine
destination-pattern 508XXXXXXX
port 0/2/0
Wilson Samuel
Level 7
Level 7
Few questions:
1. Is it on CME or CUCM Voice Gateway?
2. Could you please post the full config of the router (please attach in a notepad)
I do not have access to the full router config
RBZRVG01>show voice port 0/2/0
Foreign Exchange Station 0/2/0 Slot is 0, Sub-unit is 2, Port is 0
Type of VoicePort is FXS  VIC3-4FXS/DID
Operation State is DORMANT
Administrative State is UP
No Interface Down Failure
Description is **Fax Machine**
Noise Regeneration is enabled
Non Linear Processing is enabled
Non Linear Mute is disabled
Non Linear Threshold is -21 dB
Music On Hold Threshold is Set to -38 dBm
In Gain is Set to 0 dB
Out Attenuation is Set to 3 dB
Echo Cancellation is enabled
Echo Cancellation NLP mute is disabled
Echo Cancellation NLP threshold is -21 dB
Echo Cancel Coverage is set to 128 ms
Echo Cancel worst case ERL is set to 6 dB
Playout-delay Mode is set to adaptive
Playout-delay Nominal is set to 60 ms
Playout-delay Maximum is set to 1000 ms
Playout-delay Minimum mode is set to default, value 40 ms
Playout-delay Fax is set to 300 ms
Connection Mode is normal
Connection Number is not set
Initial Time Out is set to 15 s
Interdigit Time Out is set to 10 s
Call Disconnect Time Out is set to 60 s
Supervisory Disconnect Time Out is set to 750 ms
Ringing Time Out is set to 180 s
Wait Release Time Out is set to 30 s
Companding Type is u-law
Region Tone is set for US
Analog Info Follows:
Currently processing none
Maintenance Mode Set to None (not in mtc mode)
Number of signaling protocol errors are 0
Impedance is set to 600r Ohm
Station name RBZ_Fax_Machine, Station number 508XXXXXXX
Caller ID Info Follows:
Standard BELLCORE
Output attenuation is set to 14 dB
Caller ID is transmitted after 1 ring(s)
Translation profile (Incoming):
Translation profile (Outgoing):
lpcor (Incoming):
lpcor (Outgoing):
Voice card specific Info Follows:
Signal Type is loopStart
Ring Frequency is 25 Hz
Hook Status is On Hook
Ring Active Status is inactive
Ring Ground Status is inactive
Tip Ground Status is inactive
Digit Duration Timing is set to 100 ms
InterDigit Duration Timing is set to 100 ms
Hookflash-in Timing is set to max=1000 ms, min=150 ms
Hookflash-out Timing is set to 400 ms
No disconnect acknowledge
Ring Cadence is defined by CPTone Selection
Ring Cadence are [20 40] * 100 msec
Ringer Equivalence Number is set to 1
Andrew West
Level 4
Level 4
HI,
Is the handoff from your telco an FXO port?
Also it's a BUTT set not a BUD set..In this case BUTT = Basic Universal Telephone Test set.
Sorry about the English, princess phone.
show ver
Cisco IOS Software, C2951 Software (C2951-UNIVERSALK9-M), Version 15.2(4)M6, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Wed 19-Mar-14 17:21 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
RBZRVG01 uptime is 2 weeks, 2 days, 6 hours, 55 minutes
System returned to ROM by reload at 12:21:08 UTC Wed Feb 4 2015
System image file is "flash0:c2951-universalk9-mz.SPA.152-4.M6.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2951/K9 (revision 1.1) with 479232K/45056K bytes of memory.
Processor board ID FTX1815AJHY
3 Gigabit Ethernet interfaces
24 Serial interfaces
1 terminal line
2 Channelized T1/PRI ports
1 Virtual Private Network (VPN) Module
2 Voice FXO interfaces
4 Voice FXS interfaces
DRAM configuration is 72 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2951/K9
Technology Package License Information for Module:'c2951'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      securityk9    Permanent      securityk9
uc            uck9          Permanent      uck9
data          None          None           None
sh voice call sum
PORT           CODEC     VAD VTSP STATE            VPM STATE
0/0/0:23.1      g711ulaw   n  S_CONNECT             S_TSP_CONNECT
0/0/0:23.2      -          -  -
0/0/0:23.3      -          -  -
0/0/0:23.4      -          -  -
0/0/0:23.5      -          -  -
0/0/0:23.6      -          -  -
0/0/0:23.7      -          -  -
0/0/0:23.8      -          -  -
0/0/0:23.9      -          -  -
0/0/0:23.10     -          -  -
0/0/0:23.11     -          -  -
0/0/0:23.12     -          -  -
0/0/0:23.13     -          -  -
0/0/0:23.14     -          -  -
0/0/0:23.15     -          -  -
0/0/0:23.16     -          -  -
0/0/0:23.17     -          -  -
0/0/0:23.18     -          -  -
0/0/0:23.19     -          -  -
0/0/0:23.20     -          -  -
0/0/0:23.21     -          -  -
0/0/0:23.22     -          -  -
0/0/0:23.23     -          -  -
0/1/0         -          -  -                     FXOLS_ONHOOK
0/1/1         -          -  -                     FXOLS_ONHOOK
0/2/0         -          -  -                     FXSGS_ONHOOK
0/2/1         -          -  -                     FXSLS_ONHOOK
0/2/2         -          -  -                     FXSLS_ONHOOK
0/2/3         -          -  -                     FXSLS_ONHOOK
sh voice port sum
                                           IN       OUT
PORT            CH   SIG-TYPE   ADMIN OPER STATUS   STATUS   EC
0/0/0:23        01  isdn-voice  up    up   none     none     y
0/0/0:23        02  isdn-voice  up    dorm none     none     y
0/0/0:23        03  isdn-voice  up    dorm none     none     y
0/0/0:23        04  isdn-voice  up    dorm none     none     y
0/0/0:23        05  isdn-voice  up    dorm none     none     y
0/0/0:23        06  isdn-voice  up    dorm none     none     y
0/0/0:23        07  isdn-voice  up    dorm none     none     y
0/0/0:23        08  isdn-voice  up    dorm none     none     y
0/0/0:23        09  isdn-voice  up    dorm none     none     y
0/0/0:23        10  isdn-voice  up    dorm none     none     y
0/0/0:23        11  isdn-voice  up    dorm none     none     y
0/0/0:23        12  isdn-voice  up    dorm none     none     y
0/0/0:23        13  isdn-voice  up    dorm none     none     y
0/0/0:23        14  isdn-voice  up    dorm none     none     y
0/0/0:23        15  isdn-voice  up    dorm none     none     y
0/0/0:23        16  isdn-voice  up    dorm none     none     y
0/0/0:23        17  isdn-voice  up    dorm none     none     y
0/0/0:23        18  isdn-voice  up    dorm none     none     y
0/0/0:23        19  isdn-voice  up    dorm none     none     y
0/0/0:23        20  isdn-voice  up    dorm none     none     y
0/0/0:23        21  isdn-voice  up    dorm none     none     y
0/0/0:23        22  isdn-voice  up    dorm none     none     y
0/0/0:23        23  isdn-voice  up    dorm none     none     y
0/1/0           --  fxo-ls      up    dorm idle     on-hook  y
0/1/1           --  fxo-ls      up    dorm idle     on-hook  y
0/2/0           --  fxs-ls      up    dorm on-hook  idle     y
0/2/1           --  fxs-ls      up    dorm on-hook  idle     y
0/2/2           --  fxs-ls      up    dorm on-hook  idle     y
0/2/3           --  fxs-ls      up    dorm on-hook  idle     y
PWR FAILOVER PORT        PSTN FAILOVER PORT
