03-13-2015 09:33 AM - edited 03-18-2019 11:28 AM
Does anyone know how to configure 8800 phones for VPN? I am particularly interested on 8861/8851 models.
Carlos
03-13-2015 10:08 AM
The CUCM security guide covers the phone VPN feature, have you reviewed it???
03-13-2015 12:27 PM
Hi Jaime,
Thank you for your reply. I already checked the security guide. We have already deployed 7965 VPN phones successfully. We are testing these new models (8861/8851) and I can't get them registered through VPN, using the same profile as the 7965s. According to the guide there should be no difference. Do I have to do something different for these phones?
Carlos
03-19-2015 12:00 PM
So I opened a TAC case and they provided me with the solution:
"Usually you upload the Cisco_Manufacturing_CA certificate on the ASA but with the new models we should upload the Cisco_Manufacturing_CA_SHA2 creating a new trustpoint on the ASA"
The security guide does not specify about this cert, it only mentions Cisco_Manufacturing_CA .
Carlos
08-22-2017 11:09 AM
Can you provide more details? Thanks
