Configuring Cisco Unity Express
alap84
Hello
I want to know how to activate smart licnese for unity express mailbox abd cue ports.
I have PAK key already and smart account already associated with my cco
Any internet connconnec req for cue virtual to register. If anyone can send snapshots one by one will be much helpful
If from PAK convert to token n put in cue virtual licnese page. Will it be enough to activate mailbox licneses.
R0g22
Smart Licensing should be enabled by default starting 9.0.5
Yes, you need to have internet reach ability for CUE for http access to CSSM. Or you would need CUE to be able to reach a http/https proxy.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/unity_exp/rel9_0/online_help/cue_gui/smart_license.html
Jaime Valencia
CUE will need access to: https://tools.cisco.com/its/service/oddce/services/DDCEService over port 443 to register with the direct option.
Otherwise, you would need to install a SSMS to register it, you can do that manually or online, and then perform the license sync, which can also be online or manual.
java
if this helps, please rate
