IP Telephony and Phones
Labels
I am having issues with one of our sites that is setup with a cisco 2921 that has 4 POTS lines in a hunt connected to FXO ports on the gateway.  Local calls complete fine but when dialing long distance I get the message "we're sorry your call cannot ...
Hi,   One of our customer is looking for migrating their existing analogue telephones to Cisco IP Telephony, It's completely isolated network no connectivity to outside world. They requirement is to have minimum 50 user and maximum of 100 users, the ...
I don't need the SBC to act as a firewall, topology hiding device.   All I need it for is to terminate the service provider's sip trunk and the trunk from the CUCM.   I really don't want it to be an inline device because I need to pass both data and ...
Hi all, We have replaced an old voice gateway Cisco 2811 with a new Cisco 4331 and "ported" more or less all relevant configuration from the old to the new. All Calls incoming and outgoing are working fine to our phones. But the incoming Fax from ext...
I ran into a strange problem this weekend with a 2951. We have a CUCM, the 2951 is used as an edge device to convert from IPv6 to IPv4 and let the CUCM connect to a remote phone system. So there is a dial-peer to the CUCM and the remote system. The p...
MVK by Level 1
  • 530 Views
  • 3 replies
We have a tricky issue with elevator phones connected to analog ports on a vg350. I configured them for PLAR in CUCM (11.5) and it appears to work well, but many of the devices themselves have been historically programmed to dial certain numbers via ...
kdotten36 by Level 3
  • 2152 Views
  • 4 replies
Hi I have a gateway tjat has a FXO port who has some problems. Outgoing calls works properly, but incoming calls ring on phone in CUCM but when I answer the call is disconnect.   This is my config !voice-port 0/1/0 cptone BR connection plar opx *710...
FPENTEADO by Level 1
  • 2883 Views
  • 5 replies
Resolved! Error Pass limit
Hello,I have configured extension mobility for 300 users  and i have added 7945 phones with phone templat of 7945 in call manager.ON 7945 phones when i lift the receiver and when try to dial i get the error pass limit on the screen and no dial tone, ...
Resolved! Call Pickup Group
Hi all;           I have a doub about call pickup group, let me try to describe my envirment: 1 CUCM with tis corresponding Router Gateway to use for DN in HQ DN range (0000-9999) 1 CME that is use to config DN to an external office, DN range 4110-41...
