Configuring IVR in Cisco Unity 8.0?
Pankaj Misra
I have a Cisco Unity 8.0 (Windows Based) Server integrated with CUCM Version 8.5.1.12025-1. Here I want to enable IVR on a Single no.  and want-
A) Keys should point to a specific option like 1 for billing info, 2 for profile update  n so on.
B) How to integrate external database server (for billing info) with unity?
Can i configure all these in my existing setup or require any additional system ?
Thanks.
Pankaj
Yes, but not Unity/CUC or CUE.
You would need to buy UCCX or UCCE to do so.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
5 Replies 5
acampbell
Have a look at this link.
You need to use call handlers
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/8x/administration/guide/8xcusag040.html
Alex
Please rate useful posts
Regards, Alex. Please rate useful posts.
You do not integrate Unity to any billing system, that would be CUCM
Configuring CDR Repository Manager
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/8_5_1/admin/sacdrm.html
java
java
Hi java,
Just to make it clear, i am not specifically talking about cucm cdr billing.
I want to know, can we fetch the data from any external database server? For example i have a table in an external database server which contains user id and their bill of purchased items. In IVR if users presses 1 and specifies his user id, he will get his total bill.
I hope it will clear the scenrio. Is it possible to do so??
Pankaj
java
java
Thanks for reply.
I read the link provided by you. Its really helpful. but still i am not able to correlate the call handlers according to my requirement.
So Can you please send me any example configuration if you have?
Pankaj
