Configuring new E1 MFT
simonmossman
Hi all
Can you please confirm the correct configuration for a new E1 card install. Currently I have 1 30 channel E1 installed in the 3825 VG. I am assuming all I will have to do is add the controller and timeslots and I should be good to go. Then just add the translation patterns in the CUCM
Look forward to a reply
thanks
Simon
It should be enough if you use MGCP as protocol. Still keep in mind you need DSP to use this E1 card.
Check your show diag DSP info with DSP calculator: http://www.cisco.com/cgi-bin/Support/DSP/cisco_prodsel.pl
rate if this help
Thanks Konrad
The DSP tool is cool
