Configuring NM-HDV2-T1/E1 to connect pots to CME
ian.paquette
Im currently using a Cisco 3845 series router and running (3845-advipservicesk-9m) and CME. I am trying to connect to a Redcomm High Density Exchange Switch. My goal is to be able to make calls from my VOIP phones to my POTS phones. I am looking for a simple step by step configuration guide. any information will be helpful.
Thank you
5 Replies 5
thisisshanky
Level 11
Level 11
what type of interface do you have on the Redcomm swithc...T1 PRI ? CAS ? how many calls you want to traverse across this link ? you have to get enough ports then to size this correctly...
QSIG is a protocol used across T1 PRIs to allow for interoperability of PBXes...so i would use that..at the same time i would check what is supported by the Redcomm switch as well...
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
The redcom has a T1/ E1 card that is capable of doing either PRI or CAS. Right now we have it set up with CAS but I can change it to PRI with QSIG. We would like to have a full T1 worth of calls but can downsize if needed. The part that is giving us the most problems is actually the HDV2 card as well as the dialing-pattern. I think I have a basic understanding of the dialing-patterns but anything you might know would be very helpful.
what kind of T1 cas signalling are you using...?
Sankar Nair
We are using DTMF.
here is a sample link..
http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/cisco_ios_isdn_voice_configuration_guide/isdn09.html
http://ciscovoip-amitr.blogspot.com/2011/01/t1-cas-configuration.html
Sankar Nair
