IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6331 Views
  • 14 replies
We are looking to setup an SRST router at a branch location.  This location is connected to home office by fiber.  The branch location has a couple of PLARs that need to be available in the event of a network outage or fiber cut.  The PLARs are local...
fasteddye by Level 1
  • 593 Views
  • 1 replies
Hi,when I implement call through VPN at home, my soffphone - cisco IP communicator is error, it can not receivce and call. But when I implement call in my company network, it is ok. Before, I can VPN normally but now I can't.What is the happen?Can yo...
Hey all,I have a replacation issue in my bran spanking new cluster.  No users on it as of yet so it's a little upsetting.The history of this issue the pub had a hardrive issue.  Once fixed we had to reinstall.  Names and ip address stayed the same. T...
rbblue234 by Level 1
  • 8131 Views
  • 4 replies
Hi Guys, we gotta CUCM7.1(3) and Iexperience problem that if I set CFA CSS matching only onetranlation pattern, translation of Calling number definedin this TP doesnt work when signalizing call to outside GW.When I set this CSS for as line CSS and di...
Hi all,I have a 2851 CME router with 45 IP-Phones registering to it.Now we need to monitor (only logs) all incoming and out going calls from these extensions.Management wants to know who is dialing whom and the duration of the call.I understand that ...
Hey guys --in CUxAC, when a search is performed on the client, it only allows you to search one field at a time, so Last Name, or Number only for example, if I type in 'Smith' in the last name field, and 'John', in the first name field, it will remov...
ouhakheme by Level 3
  • 916 Views
  • 2 replies
Hi all,Could you please share, in which all cases a transcoder resource is required ?I know only about the two instances as below.1) G729 call from CUCM to Unity connection, as Unity connection only supports G.7112) CUBE environment,I would appreciat...
