ā08-06-2015 03:11 AM - edited ā03-17-2019 03:54 AM
I have an ATA that is connected to one announcement broadcasting system. Anyone initiate a call to this ATA number, voice would be broadcast. I would like to enforce a PIN similar to FAC/CMC to access this ATA number. Understand that FAC/CMC can be applied only on a route group, but is there any workaround to address this requirement?
Rgds,
Anson
Solved! Go to Solution.
ā08-06-2015 06:02 AM
Hi Anson,
You can use this guide as a reference, it was created for similar scenario
http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/118722-configure-cucm-00.html
Manish
- Do rate helpful posts -
ā08-06-2015 09:10 AM
Another way of doing it is to create a route-patten with FAC/CMC and ATA DN for same number. Both should be in different partitions. Then you send the call out to your voice gateway using the route-pattern and from the gateway loop it back to CUCM to connect to the ATA DN.
Users phones CSS should access the route-pattern only and incoming CSS for the CUCM trunk to voice gateway should access ATA DN only.
ā08-06-2015 05:52 AM
Hi Anson,
CUCM does not provide this capability apart from FAC or CMC, if you have Unity Connection , CUE or UCCX then this would be possible.
Manish
ā08-06-2015 05:55 AM
Hi Manish.
thx for the response. I do have Unity Connection. what would be the configuration for this..
Rgds/Anson
Hi Anson,
Manish
