01-07-2015 05:33 PM - edited 03-17-2019 01:31 AM
I am trying to configure a dsp resource on a router. When router was brought online there was only three vwic card configured and we used 2 vwic cards to connect two PRIs. We brought up two PRIs properly. Now after a week we connected the PVDM3 card to the router and now when I am trying to give this following command it is not recognizing it at all. Please tell me what I am missing.
Error
When I am entering
voice-card 0
It is showing Router(config)#voice-card 0
% Invalid input detected at '^' marker.
What I am missing here?
Solved! Go to Solution.
01-07-2015 06:38 PM
Yes its a licensing issue. You are not able to see voice related commands because you dont have a UC license. See below:
Index: 12 Feature: uck9 Version: 1.0
License Type: EvalRightToUse <<
License State: Not in Use, EULA not accepted <<
You have evaluation license you need to activate that. You can do that by below commands:
license boot module c2900 technology-package uck9
accept the agreement: Yes
Write memory
reload << you will need to restart the router for this to take effect.
Then check your voice commands should be working.
Ref: http://www.cisco.com/c/en/us/td/docs/routers/access/sw_activation/SA_on_ISR.html#pgfId-1155619
Let me know how you go.
-Terry
Please rate helpful posts
01-07-2015 05:42 PM
can you post sh inventory and sh run
01-07-2015 05:54 PM
#sh inven
NAME: "CISCO2921/K9", DESCR: "CISCO2921/K9 chassis, Hw Serial#: FTX1839AMP3, Hw Revision: 1.0"
PID: CISCO2921/K9 , VID: V08 , SN: FTX1839AMP3
NAME: "VWIC3-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 0", DESCR: "VWIC3-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC3-2MFT-T1/E1 , VID: V01 , SN: FOC171621H1
NAME: "VWIC3-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 1", DESCR: "VWIC3-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC3-2MFT-T1/E1 , VID: V01 , SN: FOC171621H5
NAME: "VWIC3-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 2", DESCR: "VWIC3-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC3-2MFT-T1/E1 , VID: V01 , SN: FOC171621A9
NAME: "PVDM3 DSP DIMM with 64 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 64 Channels"
PID: PVDM3-64 , VID: V01 , SN: FOC18460BGF
NAME: "C2921/C2951 AC Power Supply", DESCR: "C2921/C2951 AC Power Supply"
PID: PWR-2921-51-AC , VID: V03 , SN: QCS18290RD4
01-07-2015 06:04 PM
Ok - appears to be a licensing issue. Can you post the below:
Sh version
sh license detail
-Terry
01-07-2015 06:18 PM
sh vers
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.2(4)M6a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Tue 15-Apr-14 09:45 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
eddy115 uptime is 3 hours, 25 minutes
System returned to ROM by reload at 16:46:47 CST Wed Jan 7 2015
System image file is "flash0:c2900-universalk9-mz.SPA.152-4.M6a.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2921/K9 (revision 1.0) with 479232K/45056K bytes of memory.
Processor board ID FTX1839AMP3
3 Gigabit Ethernet interfaces
48 Serial interfaces
1 terminal line
4 Channelized T1/PRI ports
2 Channelized (E1 or T1)/PRI ports
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
255488K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device# PID SN
*0 CISCO2921/K9 FTX1839AMP3
Technology Package License Information for Module:'c2900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security None None None
uc None None None
data datak9 Permanent datak9
____________________________________________________________
sh licen deta
Index: 1 Feature: SNASw Version: 1.0
Evaluation total period: 8 weeks 4 days
Evaluation period left: 8 weeks 4 days
Period used: 0 minute 0 second
License Count: Non-Counted
License Priority: None
Store Index: 6
Store Name: Built-In License Storage
Index: 2 Feature: SSL_VPN Version: 1.0
License Count: 0/0 (In-use/Violation)
Store Index: 4
Index: 3 Feature: UCVideo Version: 1.0
Store Index: 9
Index: 4 Feature: WAAS_Express Version: 1.0
Store Index: 8
Index: 5 Feature: cme-srst Version: 1.0
Store Index: 7
Index: 6 Feature: datak9 Version: 1.0
License Type: Permanent
License State: Active, In Use
License Priority: Medium
Store Index: 1
Store Name: Primary License Storage
Index: 7 Feature: datak9 Version: 1.0
License State: Inactive
Store Index: 2
Index: 8 Feature: gatekeeper Version: 1.0
Store Index: 3
Index: 9 Feature: ios-ips-update Version: 1.0
Store Index: 5
Index: 10 Feature: ipbasek9 Version: 1.0
Store Index: 0
Index: 11 Feature: securityk9 Version: 1.0
Store Index: 0
Store Index: 1
01-07-2015 06:38 PM
Write memory
-Terry
01-07-2015 06:50 PM
Is there a way to get permanent license on that?
01-07-2015 07:07 PM
To get a permanent license you need to buy it. Normally you buy it when you order the router as a bundle. In your case, you have Eval Right to Use license.
Its eval for 60 days, after 60 days it will turn into a Right to Use license as per the document I sent you previously.
It may keep on working on RTU honor based system but there is no way you can convert into a permanent license unless you buy it.
In the end I would request to you rate all helpful posts.
-Terry
02-19-2015 12:12 PM
Hi Terry,
Could you please confirm whether we will be able to use the router for voice with right to use license?
02-19-2015 04:24 PM
I haven't tried it and also encourage you to buy the permanent licenses specially if its a production environment. It seems from here though that it will keep on functioning:
Note Starting with Cisco IOS Releases 15.0(1)M6, 15.1(1)T4, 15.1(2)T4, 15.1(3)T2, and 15.1(4)M, Evaluation licenses are replaced with Evaluation Right To Use licenses. Evaluation Right to Use licenses automatically become Right to Use licenses after the initial evaluation period. Follow the steps detailed in this section to activate an Evaluation Right to Use license.
So your current UC EvalRight to use should be automatically turned into a RTU (which normally will keep on functioning, but again I haven't tested this and will still recommed you buy permanent license for production environment)
01-07-2015 07:05 PM
It is now taking voice commands but the license is at 8 weeks 3 days. Is there a way to make it permanent?
03-17-2015 06:02 AM
I have the valid licenses but 'pri-group timeslot' is not there when I am configuring controller e1 0/0/0
my isdn interfaces doesent came up
03-17-2015 08:46 AM
Have you tried:
card type t1 0 2
or
card type e1 0 2
03-17-2015 07:55 PM
03-18-2015 06:39 AM
The config you posted shows the vwic card in slot 0 is set as T1:
card type t1 0 0
card type t1 0 1
! card type command needed for slot/vwic-slot 0/2
If you want to use E1 for the card in slot 0 you need to remove these commands and re-add as E1. Also slot 0/2 is not yet defined as a T1 or E1, to use as E1 you must define it before you can the pri-group timeslot command.
