Configuring SPA941
grantlevin
I have two SPA941 telephones that I have never used.  I have no idea how to configure them but all I would like to do is use them for intra-office communication.  In other words, I would like to connect them both to the network and just be able to use them to talk to each other.
I can't seem to get them to dial eachother's extensions.
Any help would be much appreciated.
Grant
nitsinha
Level 4
Level 4
Hi Grant,
The following are the two docs which should help you in your issue.
1) Admin guide:-
http://www.provu.co.uk/pdf/sipura/SPA941AdminGuide.pdf
2) Configuration guide:-
http://www.bicomsystems.com/docs/uad/linksys/spa-941/pdf/spa-941.pdf
Nitesh
PS:- Please rate helpful posts
