Configuring two PRI.
Rajan R
Hey Guys.
We have a PRI terminated on a voice router with CUCM 8.5. Now clients are getting one more PRI to terminate on the router. they want calls to go on PRI A if "9" is pressed and PRI B if "0" is pressed initially. How can we go about this ??
Varadarajan.R
mkchandak
If your PRI is added as MGCP, you can add the 2nd PRI as another Gateway on CUCM and create a copy of the old Route Patterns. change the 9 to 0 and point this RP to the new Gateway added on CUCM.
If you have the PRI setup as H323, you'd need to create Route Patterns with 0 dial and point it the same Gateway. On the Gateway, you need to create dial-peers which do a match based on 0 instead of 9 as it would be currently setup.
HTHs
thanks for the reply. the pri is setup as h323. I shall create dial peers to match 0 as well. So this will enable the user to use any of the two pri by dialing 0 or 9 right ??
Yes, once you add the Route Pattern and Dial-peers, you can route calls by dialing either 0 or 9
