configuring vic2-2fxs and vic2-2fxo to make call thru them
Ejiroro oki
Thanks,Below is my config and show version.All I want to do is to test the two cards by making a call thruogh,when I called the telephone it is not rigging out but there is a tone on my phone box.
Router#show run
Building configuration...
Current configuration : 1383 bytes
version 12.3
hostname Router
boot-start-marker
boot-end-marker
memory-size iomem 10
no network-clock-participate slot 2
no aaa new-model
ip subnet-zero
ip cef
ip ips po max-events 100
no ftp-server write-enable
voice-card 0
no dspfarm
archive
log config
  hidekeys
no crypto isakmp ccm
interface GigabitEthernet0/0
ip address 10.4.16.13 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface BRI2/0
no ip address
interface BRI2/1
no ip address
interface BRI2/2
no ip address
interface BRI2/3
no ip address
ip classless
no ip http server
no ip http secure-server
control-plane
voice-port 0/2/0
compand-type a-law
cptone GB
connection Tie-line 01244281361
impedance complex2
description testing
voice-port 0/2/1
voice-port 2/0/0
compand-type a-law
cptone GB
description Testing
voice-port 2/0/1
voice-port 2/0/2
voice-port 2/0/3
voice-port 2/0/4
voice-port 2/0/5
voice-port 2/0/6
voice-port 2/0/7
voice-port 2/0/8
voice-port 2/0/9
voice-port 2/0/10
line con 0
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
end
Router#
Router#show version
Cisco IOS Software, 2800 Software (C2800NM-ADVENTERPRISEK9-M), Version 12.3(11)T
11, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Thu 24-Aug-06 18:44 by dchih
ROM: System Bootstrap, Version 12.3(8r)T7, RELEASE SOFTWARE (fc1)
Router uptime is 26 minutes
System image file is "flash:c2800nm-adventerprisek9-mz.123-11.T11.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2821 (revision 53.51) with 473088K/51200K bytes of memory.
Processor board ID FHK0912F420
2 Gigabit Ethernet interfaces
4 ISDN Basic Rate interfaces
1 Virtual Private Network (VPN) Module
2 Voice FXO interfaces
8 Voice FXS interfaces
4 Voice NT or TE BRI interfaces
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
Humza Khan
first of all, you have to create dial-peers for testing fxs card.
Copy this config and paste these commands in config mode.
dial-peer voice 1 pots
destination-pattern 1000
port 2/0/1
dial-peer voice 2 pots
destination-pattern 1001
port 2/0/2
dial-peer voice 3 voip
destination-pattern 9.T
session target target ipv4:10.4.16.13
Now plug 2 analog phones on 2/0/1 and 2/0/2 ports
make a call on 1001 from 2nd phone, then make a call on 1st phone 1000.
Now for calling on your mobile no. press 9 and dial your cell no.
hopefully you will succeed in testing both cards.
Humza Khan
Thanks for your quick response, that work perfectly,I am so grateful,you saved my day.I am able to test the fxs card now.
what is left for me now is to be able to test both fxo and fxs card together,I have configured a telephone number on the fxo,so I want to be able to dial into it and let it ring out on the fxs port where the analog phone is connected.I will be glade if you can help me out.
Thanks a million.
Kaycee
