CIsco CUBE Router Outbound Call Issue
Ian Beck
HI,
I have a Cube Router configured
CUCM <-> h323 <-> Router <-> SIP <-> Telco <-> PSTN
Where when initiating an outbound call all I get is a busy tone.
However if I initiate an inbound call, which works fine.
I can then make outbound calls which work fine.
If there are no calls made for a period of time, I go back to the orginial problem.
Has any one seen a simialr probelm or have an idea wher the issue may lay !!
Many thanks
9 Replies 9
Dennis Mink
please add config, debug ccsip when making a call (we are not psychics)
Please remember to rate useful posts, by clicking on the stars below.
Tapan Dutt
Recreate the problem
- run Debugs on CUBE (debug ccsip messages, debug voip ccapi inout)
- mention calling and called party numbers
- IP address of Phone; CUCM and running conf of CUBE if possible)
Tapan
Along with the ccsip and ccapi inout debugs, please collect the below debugs for H.323 call leg.
debug h225 q931
debug h225 asn1
debug h245 asn1
Also make sure the inbound and outbound dial-peers are correctly configured.if the configuration looks fine, then with the error code captured from the debugs would help us what is wrong and where.
//Suresh Please rate all the useful posts.
I knew all this information would be required to did not have it directly to hand when I opened this discussion.
I will add as I get the info together.
A couple of debugs fro out going calls which fail :
Hi Ian,
It looks like the Telco is not responding to the SIP Invite we sent and hence the call is getting disconnected with
Cause Value=102 - CC_CAUSE_RECOVERY_ON_ TIMER_EXPIRY - Invite expires timer reached maximum number of retries allowed.
There are 3 Invite messages sent to telco but no response from them. Please have a word with them.
The intresting point is though, it would appear the Router does not send the invite, itself.
As I have watched traffic out my FW and seen nothing, when calls are made
Until I have done the inbound call, when traffic is then sent both ways !
This is the point I have got to !
Regards.
Why is traffic Blocked in direction towards TELCO on the SIP call leg. If you can fix that Calls will work.
Router is processing the call properly.
Tapan
74158  105585: *Jun 24 12:05:51 UTC: //401/80B5408F7701/SIP/Msg/ccsipDisplayMsg:
74366  105586: Sent:
74586  105587: INVITE sip:1112918888402822@Y.Y.Y.Y:5060 SIP/2.0#015
74881  105588: Via: SIP/2.0/UDP X.X.X.X:5060;branch=z9hG4bK13E34A#015
75100  105589: Remote-Party-ID: <4165727915>;party=calling;screen=yes;privacy=off#015
75352  105590: From: <4165727915>;tag=FAA2920-17B4#015
75549  105591: To: <1112918888402822>#015
75991  105592: Date: Mon, 24 Jun 2013 12:05:51 GMT#015
76237  105593: Call-ID: 3FCFF528-DBFD11E2-8309AB10-9523C09@X.X.X.X#015
76461  105594: Supported: 100rel,timer,resource-priority,replaces,sdp-anat#015
76683  105595: Min-SE:  1800#015
76899  105596: User-Agent: Cisco-SIPGateway/I
77114  105597: OS-15.3.1.T1#015
77344  105598: Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER#015
77538  105599: CSeq: 101 INVITE#015
77779  105600: Max-Forwards: 70#015
78149  105601: Timestamp: 1372075551#015
78372  105602: Contact: <4165727915>#015
78557  105603: Call-Info: ;method="NOTIFY;Event=telephone-event;Duration=2000"#015
78787  105604: Expires: 180#015
79089  105605: Allow-Events: telephone-event#015
80845  105606: Content-Length: 0#015
81048  105607: #015
>> This is the invite sent out from CUBE to Telco. better to crosscheck the FW and make sure the SIP Invite is reaching the Telco.
