01-27-2016 03:44 AM - edited 03-17-2019 05:38 AM
Hello All,
I have bought Cisco 7821 phones and unable to get them registered with CME 7.1, and have found that the current IOS does not these phones.
Please find the show version output below and recommend a suitable IOS. A quick reply will be a great help.
Router model: 2921
DRAM: 512MB
Flash: 256MB
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.0(1)M3, REL EASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Sun 18-Jul-10 03:32 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M6, RELEASE SOFTWARE (fc1)
TST-WAN uptime is 6 weeks, 2 days, 7 hours, 25 minutes
System restarted at 07:17:35 AST Mon Dec 14 2015
System image file is "flash0:c2900-universalk9-mz.SPA.150-1.M3.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2921/K9 (revision 1.0) with 479232K/45056K bytes of memory.
Processor board ID FCZ1435722Z
3 Gigabit Ethernet interfaces
1 terminal line
12 Voice FXO interfaces
1 cisco Integrated Service Engine(s)
Cisco Unity Express 7.1.7 in slot 1
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
254464K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device# PID SN
*0 CISCO2921/K9 FCZ1435722Z
Technology Package License Information for Module:'c2900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security None None None
uc uck9 Permanent uck9
data None None None
Thank you
Solved! Go to Solution.
01-27-2016 04:02 AM
CME 7.1 does not support 7821 phone models
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/requirements/guide/cme71spc.html
You can add them starting version CME 10.0 in Fast Track mode and then from CME 10.5 support for these phones is included natively.
Deepak
01-27-2016 04:04 AM
You can go with IOS version 15.4.3M4 which is the current stable one.
https://software.cisco.com/download/release.html?mdfid=282774229&flowid=7443&softwareid=280805680&release=15.3.3M6&relind=AVAILABLE&rellifecycle=MD&reltype=latest
Rajan
01-27-2016 04:02 AM
Deepak
01-27-2016 04:56 AM
Thank you Deepak!!
01-27-2016 05:07 AM
No issues, hope you had a smooth upgrade.
Deepak
01-27-2016 05:11 AM
Hello Deepak/Rajan,
configuration is same as other SIP phones
Voice register global???
01-27-2016 05:14 AM
Correct, no change there
https://communities.cisco.com/thread/39200?start=15&tstart=0
Deepak
01-27-2016 05:27 AM
Thank you for your quick reply and help
01-27-2016 06:43 AM
Hello Deepak/Rajan,
I have upgraded the IOS but none of the phones coming up, pls help
01-27-2016 06:58 AM
Can you provide the phone configuration and also confirm the below:
1. Whether the phone is getting IP address and TFTP details from DHCP
2. What is the status message showing on the phone
3. Below debugs for one phone which you are trying to register along with MAC address of phone
debug ccsip messages
debug tftp events
Rajan
01-27-2016 07:02 AM
I am referring to the existing phones (7911, 7945 and CIPC) , and the new phones 7821 are yet to be configured.
For your information I have existing running-configuration available on the router
01-27-2016 07:07 AM
Can you configure this and try now:
voice service voip
no ip address trusted authenticate
There is toll fraud feature starting wiwth IOS 15.1 (2). So configure this and the phones will register. Later you can enable this feature and add all the required IP address using the below procedure
http://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/112083-tollfraud-ios.html
Rajan
01-27-2016 07:10 AM
sure, will do that
01-27-2016 07:33 AM
I have done this but no luck
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol pass-through g711ulaw
sip
bind control source-interface GigabitEthernet0/1.10
bind media source-interface GigabitEthernet0/1.10
registrar server expires max 600 min 60
sh ephone registered
No ephone in specified type/condition.
01-27-2016 07:51 AM
phones display show
configuring IP, please help
01-27-2016 08:12 AM
Rajan,
I am struck, please help
do I need to configure load command under telephony-service???
