ā05-05-2018 05:11 AM - edited ā03-17-2019 12:45 PM
Hi guys,
I have two remote site of CUCM (one site has E1 and one has SIP) can I connect between both sites to be able to call local phones with each other between two sites?
or I need to make both SIP?
Mohammad Saeed
Solved! Go to Solution.
ā05-05-2018 10:15 AM
i have many customer with the same scenario what you have. i did ICT for most cases. There are some other way as well SIP trunk or CUBE also. but i prefer to use ICT and for you i recommend to do inter-cluster trunk to avoid confusion and make it simple.
Saiful Islam
ā05-05-2018 07:15 AM
What I understand is, there are two different CUCM clusters with one having E1 and other having SIP service provider connections. If you have WAN connectivity between clusters it users can call call each other through WAN irrespective of the PSTN connection type. Create a SIP trunk between cluster, or use inter cluster trunk (SIP will be preferred for me). If you are looking for something else please elaborate your question
ā05-05-2018 08:10 AM
So doesnt matter about the type if lines from isp E1 or SIP.
But how to know if i use WAN connection.
And i can configure sip connection between two cucm remotely even if i dont buy a sip line from isp?
ā05-05-2018 08:23 AM
ā05-05-2018 09:07 AM
Every site has its own pub+sub. Will consider two different cluster?
ā05-05-2018 09:18 AM
ā05-05-2018 09:24 AM
Thanks for ur support. So i can use sip sitting between 2 clusters and the sip peer will be the voice gw wan ip address? And how to check if two voice gw have wan connection? Through ping?
ā05-05-2018 09:46 AM - edited ā05-05-2018 09:49 AM
If your every site has its own pub+sub, it is consider as two different cluster. for this scenario if you have IP network connection between two site by intranet or VPN, ideally you should configure inter-cluster trunk between this two CUCM cluster. no more confusion. for this case you dont need to think about your E1 link or SIP trunk from service provider. Link E1 or SIP from telco Service provider is used for external calls mainly, not for inter site call.
I have vpn from internet Router gateway not from voice gateway?
ā05-05-2018 09:54 AM
The costumer has MPLS between two sites!
ā05-05-2018 10:01 AM
The costumer has MPLS between two sites. Means both CUCM cluster can reach each other without VPN. if they are reachable by their MPLS connection, just do ICT without any confusion.
Saiful Islam
CCIE Collaboration
ā05-05-2018 10:02 AM
ā05-05-2018 09:57 AM - edited ā05-05-2018 09:58 AM
you have vpn from internet Router gateway, not from voice gateway. This is ok. you should do Inter-cluster trunk only between two CUCM cluster. Nothing is dependent with your voice gateway for doing inter-cluster trunk. dont be confused with voice gateway or E1 or SIP trunk on Voice gateway. even if voice gateway is shutdown also no problem with your inter-cluster trunk. calls between this two CUCM cluster will work through your VPN by internet router.
Saiful Islam
CCIE Collaboration - 51594
ā05-05-2018 10:13 AM
Thanks for all now the Idea is clear, Is there any clear document or video show how to to make ICT with MPLS case..would be appreciated
ā05-05-2018 10:30 AM - edited ā05-05-2018 10:33 AM
You can see the below link:
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/11_5_1/sysConfig/CUCM_BK_SE5DAF88_00_cucm-system-configuration-guide-1151/CUCM_BK_SE5DAF88_00_cucm-system-configuration-guide-1151_chapter_01111.html
you may see the below video, catch after 6 min for starting ICT configuration
https://www.youtube.com/watch?v=zozAFO0MrMk
Please rate my post if it is helpful to you.
Saiful Islam
