Connecting CME with CUCM
harish9211
Please anyone help me i want to make communication between CME and CUCM.
For this i knw i need to make h323 gateway between dem and dial peers on that gateway.
Please anyone suggest me is there anythng othser thing to configure on gateway or on CUCM.
I have installed CUCM on vmware workstation and CME on GNS3.
um jst making dis lab on my laptop.
Please help...
Thanks and R's,
Harish
testeven
Hi Harish,
To integrate CUCM and CME follow steps below:
1. Add the CME as a H.323 gateway in the CUCM.
2. Configure a Route Pattern that routes the calls to the destination of the CME, for example a
2XXX if your CME has this type of extensions and assign the H.323 GW to this Route Pattern's GW/Route List.
3. Apply the following command in the CME:
    H323-gateway voip bind srcaddr
4. Add a dial-peer in the gateway that points in the direction of CUCM.
Tere.
If you find this post helpful, please rate!
Regards, Tere. If you find this post helpful, please rate! :)
Hi Harish,
If you are integrating CUCM and CME via SIP, then follow Tere's steps above with SIP trunk add to CUCM.  Here is an example of SIP dial-peer in the CME:
dial-peer voice 3050 voip
destination-pattern 3...
session protocol sipv2
session target ipv4:x.x.x.x
incoming called-number .
dtmf-relay sip-notify
voice-class code 1
no vad
