09-20-2016 01:08 AM - edited 03-17-2019 08:08 AM
I have a requirement
Any idea how to achieve this? Thanks in advance
09-20-2016 01:43 AM
What's you're environment CME or CUCM? Also what are you using as your Gateway? SIP / CUBE, MGCP or H.323?
Rob
09-20-2016 01:56 AM
We are using CUCM and we are using MGCP
09-20-2016 04:48 AM
I take it your Hunt Pilot is configured as an external number? You are able to dial the Hunt Group from Outside? Or you have a Translation Pattern that translates an external number into the Internal Hunt Pilot number?
If so you will need to configure the External Number Mask in the Device Profile or Directory Number for each member of the Hunt Pilot to that external number. You will then need to check the box for "Use Calling Party's External Phone Number Mask" in the Route Pattern for outbound calls to your MGCP Gateway.
This should make the Caller ID display as the Hunt Pilot or the Translation Pattern for the Hunt Pilot instead of the Inidividuals DDI.
Hope this helps.
Rob
09-20-2016 05:16 AM
Thanks Rob. I will try this. Really appreciate your help.
09-20-2016 05:43 AM
09-20-2016 05:44 AM
Correction, that is not an error but just a message.
09-20-2016 05:48 AM
That message is fine and can be ignored. I'm glad it's working for you.
