COR (Class of Restriction) configuration of CIPC Phone register in CME 10.5
anilkumar.cisco
Level 4
Level 4
Hello Friends,
I have CME 10.5
and registered CIPC phone there..
ephone-dn  1
 number 5805
 name Bob
ephone  200
 mac-address F8B1.56C9.B225
 type CIPC
 button  1:1
Incoming and outgoing is working perfectly and COR configuration is working perfectly with SIP Phones i.e. Cisco 3905 and Cisco 7821.. but when I am trying to apply COR configuration in CIPC.. I am not able to find any option in ephone configuration option.
I am using ISR 4321 Version 03.16.05.S - (recommended one)
Enclosed is the show run of the router for your consultation and kindly ignore the IP sheme or ip available on the show runn
Apply the COR list on the Ephone-dn and see if that works or not.
Abhay
Kindly rate all helpful posts !!!
Abhay Singh Reyal
The Only Way To Do Great Work Is To Love What You Do. If You Haven’t Found It Yet, Keep Looking. Don’t Settle
option , not coming..
