cor list configuration CME 12
akhundbilal
I have configured COR, Please advise if i have done it correctly, as it is not working, where am i doing mistake.
dial-peer cor custom
name Mobile
name Local
name NWD
name Int
name UAN
name Toll
name Local-BR
name All
name internal
name Mobile-GSM
dial-peer cor list Level3
member Mobile
member Local
member UAN
member Toll
dial-peer cor list All
member All
dial-peer cor list internal
member internal
dial-peer cor list Mobile-GSM
member Mobile-GSM
member Mobile
dial-peer cor list Local
member Local
dial-peer cor list NWD
member NWD
dial-peer cor list Int
member Int
dial-peer cor list UAN
member UAN
dial-peer cor list Toll
member Toll
dial-peer cor list Local-BR
member Local-BR
dial-peer cor list Level1
member internal
dial-peer cor list Master
member Mobile
member Local
member NWD
member Int
member UAN
member Toll
member internal
ephone-dn 18 dual-line
number 218
label 218
description Huddle Room
name Huddle Room
corlist incoming Master
Thanks, did i applied it right.
Here is a sample config.
Class Of Restriction.
Defining the cor list
 name GSM
 name Landline
 name Local
 name INTERNATIONAL
dial-peer cor list GSM
 member GSM
 member Landline
 member Local
dial-peer cor list INT
 member GSM
 member Landline
 member Local
 member INTERNATIONAL
dial-peer cor list Landline
 member Landline
 member Local
 member Local
dial-peer cor list gsm
 member GSM
dial-peer cor list landline
 member Landline
dial-peer cor list local
 member Local
applying inbound cor list
voice register pool  1
 busy-trigger-per-button 2
 id mac 5067.AEE3.866B
 type 7841
 number 1 dn 1
 cor incoming GSM default
 dtmf-relay rtp-nte sip-kpml
aplying outbound corlist
dial-peer voice 2 pots
 trunkgroup TRUNK
 corlist outgoing gsm
 description ##DIAL_PEER_GSM##
 destination-pattern 9[79].......
Response Signature
TechLvr
Your configuration seems to be correct.
Have you applied restrictions to any dial peers such as the example below?
Dial-peer voice 1000 pots
Destination-pattern 800T
Corlist outgoing Toll
You only seem to have configured half of the needed configuration. You’ll need to configure this on the outgoing direction as well, otherwise all is allowed as that’s the default option for COR if nothing is configured.
Response Signature
 name GSM
 name Landline
 name Local
 name INTERNATIONAL
 member GSM
 member Landline
 member Local
 member GSM
 member Landline
 member Local
 member Landline
 member Local
 member Local
 member GSM
 member Landline
 member Local
 type 7841
 number 1 dn 1
 trunkgroup TRUNK
Response Signature
