CORPORATE DIRECTORY **HOST NOT FOUND**
Chrysostomos_CY
Level 5
Level 5
Hi to all
i have a strange problem here
Everyhting was ok, but wihtout any reason the corporate directory stoped to work(host not found)
Phones: 9951 and 7945
work senario:
I have restarted cisco tomcat.Then reset all phones(NOTHING CHANGED)
1) Then i performed a hardware reset on some 7945 and this seems to work (Is any other solution? I have to perform a hardware reset an a 200 phones?>)
Do you wnow waht causing this issue?
2) Now on 9951 phones i couldnt perform a hardware reset(is not like the other phones?)
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
2 Accepted Solutions
shalushar
Level 7
Level 7
If you are getting Host not found error then please find below of the steps to remove this error:-
  • Make sure to change hostname to ip address under System->Server.
  • As a workaround, remove the Secure URL entry for Directory URL under the Enterprise Parameters.
  • Make sure that the firewall settings are not blocking access.
  • Restart the Cisco Trust Verification Service.
  • Also refer to the link below for more information
    http://www.cisco.com/en/US/partner/products/sw/voicesw/ps556/products_tech_note09186a0080a5b7af.shtml
    Tx,
    Shalu
    Do you mean a factory reset ?
    factory reset on this phone by doing the following procedure :
             1. Power off and power on the phone while pressing #
             2. When you see the red LED lit on the MUTE key.
             3. Enter 123456789*0# to initiate factory reset. (before LEDs are lit as Orange)
    Pierre.
    7 Replies 7
    shalushar
    Level 7
    Level 7
    Tx,
    Shalu
    HI SHALU
    Thank you for the answer
    I will check it and rturn back with an update
    Does Ayones now how to perform a hardware reset on 9951 phones
    The typical Procedure is not working
    Pierre.
    Thanks a lot
    Chrysostomos
    Sent from my iphone
    I have removed the security directory URL and performed a fardware reset on all phones
    After that the problem solved
    Thank you for your help
    By doing this the phone will communicate with the CUCM over HTTP right ?
