CP-6921 cannot register with CM7.1.5?
schenkernz
Hi all,
New to this forum here.
I have the problem with registering 6921 to our call manager, it's not getting ip address from DHCP, however, another phones like 7945, 7942, 7962 have no problem what so ever...
Workarounds I've tried were manually putting static ip address or change the port mode to trunk, then the phone works fine, however it's not the permanent solution.
If someone had the similar problem and let me know what's your solution will be much appreciated!
Hi Eric,
the SCCP image 9.0.3.0 is a deferred release.
Try uploading the latest image 9.3(3)SR1 on one of the phones and check.
regds,
aman
9 Replies 9
Dennis Mink
Are these phones new out of the box?
Please remember to rate useful posts, by clicking on the stars below.
Hi Dennis,
Yes, these phones are new out of the box, cheers
Aman Soi
Hi Eric,
What is the firmware version u are using?
Could be a bug.
regds,
aman
Hi Aman,
Thanks for te reply, the firmware ver. is 9.0.3.0, cheers
Hi Eric,
You are using old firmware and below bug is DHCP related bug for same phone. This bug affect all the modela so may be not your case But you can upgrade the firware and see.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCth34329
Ronak Patel
Rate all helpful post by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Hi Eric,
regds,
aman
William Morales
If the firmware upgrade doesn´t solve the issue, make sure you are pointing the IP phone to the correct DHCP server. You can span a switchport on the switch you are connecting the device, to get a packet capture. That will let you know what the phone is receiving when it´s sending the DHCP request. It may be a vlan configuration error on the switchport.
Here you have another thread where they explain how to span a switchport:
https://supportforums.cisco.com/docs/DOC-2632
Regards.
schenkernz
Hi guys, really appreciate your great help, the phone can register to the CM after we upload the new firmware. Thanks a lot :-)
Hi Eric,
Thanks for update.
Good problem is resolved.
regds,
aman
