10-27-2010 02:29 AM - last edited on 03-25-2019 08:02 PM by ciscomoderator
I have a problem similar to https://supportforums.cisco.com/message/1163554 here. I have 7937 Conference Phones which sould work with the Powercubes. For that we bought CP-7937-PWR-SPL=. We have two Phones and two splitters. The 7937s are booting without any problems when on POE, but with none of the Power Splitters (no power at all). I also tried a Power Injector, which did not work too (But this was vrom WLan-Equipment and might not provide enough power). Thats strange as we have two phones and two power-adaptors and i think its unlikely that both are faulty?
Any Ideas?
Solved! Go to Solution.
10-27-2010 05:55 AM
Check out 3-5 here: http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7937g/6_0/english/administration/guide/37adm60.pdf. Make sure that it is plugged in correctly or you won't get power to the phone. I've seen this connected the wrong way causing the problem.
10-27-2010 04:06 AM
Are you sure that you have the Power Cube 3 (CP-PWR-CUBE-3) rather than the older Power Cube 2 (CP-PWR-CUBE-2)?
I do not believe that the older model supports the 7937
10-27-2010 04:14 AM
They are CP-PWR-CUBE-3= so its definitly Powercube 3. Also i dont think a simple 48V Power Supply can support or not support specific functions or Phone Models?
10-27-2010 05:55 AM
10-27-2010 06:39 AM
Shame on me! You are absolutely right. I just plugged the RJ45-Plug of the Splitter in the Phone and the Power to the Splitter - not working. I would not in my wildest dreames have thinked of plugging a Patch-Cable on the other end of the splitter ant that to the phone. Sorry for my ignorance - looks like it sometimes MAKES sense to look in the manual for things like plugging in a cable
