CP-8831 delete ITL file
Hi, I have a CP-8831 connected to one cluster running CUCM 8.6 but I want to move the phone to another cluster running CUCM 8.6
How do I delete the ITL file on this model?   I don't see a possibility to delete the ITL file as there is for a 7900 series phone.
Peter.
Stephen Welsh
Level 4
Level 4
Hi Peter,
The only way I belive you have remote the ITL File from that model of phone remotely is by setting the Enterprise parameter of "Prepare Cluster for Rollback to pre 8.0" to true, then reset the phone(s) for that setting to take effect.
There are a lot of considerations for ITL (and CTL) files with the introduction of Security by Default, I strongly recomend getting a full understanding of Security by Default and it's implications, UnifiedFX (The creator of PhoneView) are hositng a series of educational webinars on this subject:
The Essentials of Endpoint Security & Compliance
• Session 1: The Impact of Security by Default (5th Sept)
• Session 2: Understanding and Managing ITL & CTL Files (12th Sept)
• Session 3: Leading Practices for Endpoint Security & Compliance (19th Sept)
Spaces are limited and we anticipate high demand, so please register early:
http://events.unifiedfx.com
Kind Regards.
Stephen
I found the correct solution:
In the Menu, go to Admin Settings --> Reset Settings --> Select Security.
This will delete the ITL file.
Peter.
Bernd Disa
Nice Link for all who search for the factory reset sequence:
https://supportforums.cisco.com/discussion/12429241/8831-factory-reset
imzloy
Found free 30 days software for remote phone control which can delete ITLs, update phone background images etc.: http://www.awnmtech.com/prcut-download/
