CP-8845 on Panasonic (KS-NS 300 )
amolwable123
The ask from the customer is to configure CP-8845 video phone, on Panasonic (KS-NS 300 ).
Can we achieve this? If yes, what is the procedure?
Jonathan Schulenberg
This is a question for Panasonic but ensure the phone is running MPP firmware as a starting point; the Enterprise firmware is only intended for Cisco call control.
Convert between Enterprise Firmware and Multiplatform Firmware for Cisco IP Phone 7800 and 8800 Series Guide
Cisco IP Phone 8800 Series Multiplatform Phone Administration Guide for Release 11.3(1) and Later
AFAIK KS-NS 300 is a IP PBX which support SIP phones. Technically you should be able to use a 8845 if the phone is on MPP firmware.
You must refer guides released by Panasonic  regarding  third party sip phones.
Kindly verify the existing  firmware. if its on enterprise versions, follow the guide shared by @Jonathan Schulenberg  to  convert the phone to MPP before you try with Panasonic. Conversion is not free, cost involved.
How to configure them on Panasonic, you must refer Panasonic guides. You wont be able to find this info on Cisco.
Response Signature
Leo Laohoo
Personally, I would not make any attempt to do so.
For a start, the phones will need to be converted to 3PCC/MPP firmware.  Next, users will need to get Service Contract to download firmware because the integration could run into a brick wall of bugs (which requires a Service Contract to download firmware).
Bugs discovered will need to have Service Contract to report them to TAC.  If the bugs are never seen before, it will take several years for the bugs to get fix.
To sum it all up, it is not worth it.
