03-10-2023 02:02 PM
I am trying to connect a CP-HS-WL-561-S-US to a CP-8861 to a PC. I made sure that the Y-Splitter is plugged to the AUX and headset ports on the phone and the other end on the headset base. I also plugged the USB cord from the phone to PC. I am able to send and receive calls however, my PC will not detect the 561 or the CP-8861 as an audio source. It does not come up in device manager either. I am trying to set the PC's default audio source to the 561 to get the headset to ring instead of the phone.
03-11-2023 12:52 AM
What you exactly mean by your PC will not detect 561 or the CP 8861 as the audio source. I assume you are trying to connect 8861 to your PC as an audio source through bluetooth. If yes, it doesn't work as you expected.
03-15-2023 11:42 AM
The 561 connections to the CP-8861 via Y-splitter. Then, I plug the CP-8861 to the computer via USB. The CP-8861 does not show up in device manager.
03-29-2023 06:52 AM
Bump
