CRC4 and slip error
bluesea2010
Level 5
Level 5
sh controllers e1
E1 0/1/0 is up.
Applique type is Channelized E1 - balanced
No alarms detected.
alarm-trigger is not set
Framing is crc4, Line Code is HDB3, Clock Source is Line.
International Bit: 1, National Bits: 11111
Data in current interval (128 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
5 Slip Secs, 4 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
9 Errored Secs, 0 Bursty Err Secs, 4 Severely Err Secs, 0 Unavail Secs
Total Data (last 24 hours)
8070 Line Code Violations, 33 Path Code Violations,
305 Slip Secs, 310 Fr Loss Secs, 4 Line Err Secs, 0 Degraded Mins,
608 Errored Secs, 0 Bursty Err Secs, 303 Severely Err Secs, 78231 Unavail Secs
I am getting  the  above errors ,
Is that normal or can can we do something to solve the error
Is that e1 physical layer issue
6 Replies 6
R0g22
Attach your gateway config.
Here is the   conf
version 15.5
service timestamps debug datetime
service timestamps log datetime msec localtime
service password-encryption
no platform punt-keepalive disable-kernel-core
hostname GW1
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
card type e1 0 1
no logging queue-limit
no logging buffered
no logging console
no logging monitor
aaa new-model
aaa authentication attempts login 10
aaa authentication login default none
aaa authentication login ssh group tacacs+ local-case
aaa authentication login console none
aaa accounting session-duration ntp-adjusted
aaa accounting connection h323 start-stop group radius
aaa session-id common
subscriber templating
isdn switch-type primary-net5
c
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
h245 tunnel disable
sip
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice-card 0/1
no watchdog
voice-card 0/2
no watchdog
license udi pid ISR4321/K9 sn FDO216778787
redundancy
mode none
controller E1 0/1/0
pri-group timeslots 1-31
vlan internal allocation policy ascending
gw-accounting syslog
interface GigabitEthernet0/0/0
ip address 192.168.2.10 255.255.252.0
negotiation auto
h323-gateway voip bind srcaddr 192.168.2.10
interface GigabitEthernet0/0/1
no ip address
shutdown
negotiation auto
interface Service-Engine0/1/0
interface Serial0/1/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
interface Service-Engine0/2/0
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
interface Vlan1
no ip address
shutdown
ip forward-protocol nd
ip http authentication local
ip http secure-server
ip tftp source-interface GigabitEthernet0
ip route 0.0.0.0 0.0.0.0 192.168.2.1
ip ssh authentication-retries 5
ip ssh version 2
control-plane
voice-port 0/1/0:15
bearer-cap Speech
voice-port 0/2/0
timing hookflash-out 50
connection plar opx 5111
voice-port 0/2/1
connection plar opx 5200
voice-port 0/2/2
connection plar opx 5400
voice-port 0/2/3
bearer-cap Speech
no mgcp package-capability res-package
no mgcp package-capability fxr-package
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer voice 8001 pots
destination-pattern 001T
port 0/2/1
prefix 00
dial-peer voice 8002 pots
destination-pattern 002T
port 0/2/2
prefix 00
dial-peer voice 8003 pots
destination-pattern 003T
port 0/2/3
prefix 00
dial-peer voice 10 pots
destination-pattern [135].......
direct-inward-dial
port 0/1/0:15
dial-peer voice 11 pots
destination-pattern 18.....
direct-inward-dial
port 0/1/0:15
prefix 18
dial-peer voice 12 pots
destination-pattern 1[0-7,9].
port 0/1/0:15
prefix 1
dial-peer voice 202 voip
preference 10
destination-pattern 17404...
session target ipv4:192.168.1.100
voice-class codec 1
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 501 voip
session protocol sipv2
incoming called-number .
voice-class codec 1
dtmf-relay rtp-nte
dial-peer voice 8000 pots
destination-pattern 000T
port 0/2/0
prefix 00
dial-peer voice 13 pots
destination-pattern #1[0-7,9].
port 0/1/0:15
prefix #1
dial-peer voice 401 voip
preference 9
session target ipv4:192.168.1.101
voice-class codec 1
no vad
You did not attach the complete configuration. Since this is an ISR-4k, the clocking is a bit different than the previous gen ISR's.
Do the following -
network-clock synchronization automatic
no network-clock synchronization participate 0/1
Do a "clear counters" and then monitor the slips.
Thanks for the reply ,
The file is quite long due to the fax dial peer configuration , and I sanitized the user infos ,
It would be great if you could say which important information are  missing in the config file
I already highlighted the changes that need to be done. Please check my last post.
Slips are sync errors.
Do you have try these commands?
network-clock-participate
network-clock-select
Regards.
