CTI-RP having Errors
julienf28
I have a CTI-RP with multiple lines associated to it. One of the administrators deleted lines on this RP and ever since then I've been having this error showing up on the RP once I click on the line.
Error MessageUnmapped Exception Index: 22, Size: 21
I can't delete or remove the line itself unles i'm in the global search erea in UCM.
Ideas?
shalushar
Level 7
Level 7
Did you try to move the associated extensions to a new CTI RP and then delete this.
Tx,
Shalu
