Cius works on CM8.0
scottsassin
I just received a Cisco Cius Tablet for evaluation.  Can it run on CM 8.0.1?  We were able to use the Jabber for Android.
testeven
Cius is not supported with CUCM 8.0.  It will work with 7.1.5, 8.5, and later.  Right now only 8.6 supports it natively.
Tere.
If you find this post helpful, please rate!
Regards, Tere. If you find this post helpful, please rate! :)
Is there any place to get a configuration guide?  I have looked everyware, and can not find a guide.
Hi Scott,
Please check this doc:
https://communities.cisco.com/docs/DOC-24585
HTH!
Tere.
Scott,
I've got the CIUS workin on my CUCM 8.5 cluster without any problems. It was a pretty easy setup and just had to make sure the correct files were installed for the firmware. TAC doesn't support the CIUS for CUCM unless you have it on the firmware that is available on CCO. Go here for the firmware:
http://www.cisco.com/cisco/software/release.html?mdfid=284010532&catid=278875240&softwareid=284006003&release=9.2%281%29&relind=AVAILABLE&rellifecycle=&reltype=latest
The active load can be found by going to Settings->About Cius->Active Load.  If 'dev' appears anywhere in the filename then it's a used device from the Beta or EFT and is not supported by TAC.
Ryan
