05-03-2016 04:55 AM - edited 03-17-2019 06:48 AM
Hi All,
I would like to configure HA on two cisco 4331 CUBEs.
My understanding this can be done with Redundancy Group Infrastructure configuration.
Redundancy Group Infrastructure requirement is to have a 3rd connection via a switch for HA keep-alives, checkpointing.
The 4331 box has only 2x RJ45 based ports so there is a missing one for the Redundancy Group configuration.
The NIM cards (eg. NIM-ES2-4) seems only for Layer2 configuration.
Am I missing something or this box can not be configured for HA?
Many thanks for your time and help
Tibor
05-03-2016 05:05 AM
Hi Tibor,
The HA options on ISR 4000 series are given here
http://www.cisco.com/c/en/us/td/docs/routers/access/4400/software/configuration/guide/isr4400swcfg/configuring_high___availability.html
Manish
05-03-2016 05:54 AM
Hi Manish,
Many thanks for the link, this seems quite general one.
As mentioned I have 2x 4331 boxes.
Can you please tell me if this particular box supports HA configuration ( with Redundancy Group Infrastructure)?
Regarding the Redundancy Group Infrastructure configuration this requires a 3rd interface but by default there is only 2x RJ45 based ports on 4331, so there is a need to add a NIM card (NIM-1GE-CU-SFP), if I'm correct.
Can you please tell me, if in this case Hw is okay for HA configuration with Redundancy Group Infrastructure configuration?
Many thanks,
Tibor
11-25-2016 07:02 AM
Hi Tibor,
Did you ever get this answered?
11-01-2018 08:58 AM
