CUBE capacity with isr 4331
foued kh
Hi team,
I purchase an ISR4331 with FL-CUBE-5 in bunde but i need more capacity.
My question is, i have to add a seperate license for CUBE or what i have to do please?
I mean if i want to have 30 sessions , i have to add an FL-CUBE-25= ?
2 Accepted Solutions
Philip D'Ath
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/cube/configuration/cube-book/voi-cube-licensing.html
Cisco Unified Border Element License Types
Two types of Cisco Unified Border Element licenses are available:
  • Pay-as-You-Grow (or session count) license—This type of license covers the right to use the feature as well as the maximum session count allowed. An example is the FL-CUBE-25 license, which allows up to 25 sessions. This license is designed to allow a specific number of sessions (or calls) on a platform. Purchase only as many sessions as are required in your deployment. You can add more licenses later as your needs expand, thus offering pay-as-you-grow benefits. Session licenses are stackable. These licenses are available on select platforms as shown in Table 1 in the section CUBE Licenses, and are available on all software images. Examples include the FL-CUBE-4 and FL-CUBEE-100 licenses.
  • Platform (or flat) license—This type of license covers the right to use the feature up to the maximum session count supported on the chosen platform. An example is the FL-INTVVSRV-2811 license, which allows the maximum number of sessions the Cisco 2811 platform supports. These licenses are available on select platforms as given in Table 1 in the section CUBE Licenses. Examples include the FL-INTVVSRV-2801 and FL-GK-3945 licenses.
Hi Foued,
You can check the following
Table 7.       Ordering Information for Feature Licenses
Part Number (SKU)
Description
FL-CUBEE-5(=)
Feature license applicable to the Cisco 2900, 3900 and 4000 Series platforms for 5 simultaneous IP-to-IP Gateway sessions
FL-CUBEE-5-RED(=)
Feature license applicable to the Cisco 2900, 3900 and 4000 Series platforms for 5 simultaneous IP-to-IP Gateway sessions with dual redundancy option
FL-CUBEE-25(=)
Feature license applicable to the Cisco 2900, 3900 and 4000 Series platforms for 25 simultaneous IP-to-IP Gateway sessions
FL-CUBEE-25-RED(=)
Feature license applicable to the Cisco 2900, 3900 and 4000 Series platforms for 25 simultaneous IP-to-IP Gateway sessions with dual redundancy option
You can check with your local Cisco SE before ordering.
http://www.cisco.com/c/en/us/products/collateral/unified-communications/unified-border-element/data-sheet-c78-729692.html?cachemode=refresh
Manish
Philip D'Ath
Thank you philips for the clarification.
One last question please ; the number of sessions in CUBE is compared to the number of simultanious connection through SIP trunk ?
i mean if i need for example a max of 30 simultanious communications through SIP link to the external world or from the external world, i have to purchase a CUBE License with 30 sessions ?
Hi Foued,
Part Number (SKU)
Description
FL-CUBEE-5(=)
FL-CUBEE-5-RED(=)
FL-CUBEE-25(=)
FL-CUBEE-25-RED(=)
Manish
thank's for all, Philips and Manish
