CUBE Changing Diversion Header
ailhan001
I want to change Diversion header from: 6090........ to: 02123766100
This is my rule:
voice class sip-profiles 100
request INVITE sip-header Diversion modify "<sip:6090........@>" "<sip:02123766100@>"
I also added this profile under dial peer:
dial-peer voice 11 voip
description to To_TT_Sehirici
destination-pattern 0..........
progress_ind setup enable 3
rtp payload-type cisco-codec-fax-ack 120
rtp payload-type nte 97
session protocol sipv2
session target ipv4:XXXXXXX
session transport udp
voice-class codec 1
voice-class sip profiles 100
voice-class sip options-keepalive up-interval 180 down-interval 60 retry 3
voice-class sip bind control source-interface GigabitEthernet0/0/0.200
voice-class sip bind media source-interface GigabitEthernet0/0/0.200
dtmf-relay rtp-nte
no vad
But diversion header doesnt change. I guess my rule is wrong. Can you help me to fix that?
Try this.
request INVITE sip-header Diversion modify ”Diversion:(.*)(sip:)(6090........)(@.*>)” ”Diversion: \202123766100\4”
Response Signature
Try this.
Response Signature
Oruc Akpinar
Hello
Usually, sip profile configuration doesn't work. You can simply use translation-rule, translation-profile, and CSS/PT
voice translation-rule 1919
rule 1 /^\(2...\)/ /0212111\1/
voice translation-profile 1919
translate redirect-target 1919
translate redirect-called 1919
dial-peer voice 19 voip
description OUTBOUND DIALPEER ****
translation-profile outgoing 1919
after those configurations, you need to add called transformation with the new partition/CSS on CUCM. and after that, select this CSS as Call Forward All CSS. at the same time, you should select the same CSS on the CUBE TRUNK.
Has been forwarded calls should go through a new Route Pattern.
Create those;
- CFDALL-PT
- CFDALL-CSS
- CFDALL-RP > 0.0! > Calling Party Transform Mask > XXXXXXXXXXX (or you can use phone number mask option)
- Select this CSS on CUBE TRUNK and check the box Redirecting Diversion Header Delivery - Outbound
- Select this CSS on the Phone associated Line as Call Forward All option
The main reason behind this you need to separate Forwarded Calls and Regular Calls.
Regards.
@Oruc Akpinar wrote:
Hello
It’s a matter of correct definition of the sip profile. If it’s correctly setup it works.
Response Signature
