CUBE configuration with CUCM Call Manager
sarwarm123
Our company recently decided to have a SIP trunk in our Cisco VOIP environment. I have not configured CUBE router before so I have read number of documents related to CUBE configuration with CUCM. However I still have confusion so I need your help. Please see proposed network diagram below.
My Question is, do we connect one gig port to company LAN where CUCM is connected and second gig interface will connect to SIP Provider customer end router? For example
interface GigabitEthernet0/0
description Connection to LAN
ip address 172.102.243.10 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
description connection to SIP Provider
ip address 99.102.153.24 255.255.255.0
duplex auto
speed auto
I have seen some other sample configurations where people configured only one gig port for example (I have also attached full sample configuration)
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
no ip address
shutdown
duplex auto
speed auto
service-policy output VOIP-Policy
description $ES_LAN$
ip address 146.191.201.41 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 146.191.201.41
65 Replies 65
Hi Aok,
It just because of your help its working. Next step is to test outbound calls. Many thanks once again
Hi Aok,
Now I am having an issue with digit translation, basically I want to translated DNIS 02476012665 to internal 5 digit VOIP number 88000. I tried num-ex command but thats not working. I also tried to apply voice translation rule but getting Called Number not translated
Called Number=02476012665(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
I think I am doing worng translation, can you please help me in this. Also do I need to add outgoing dial-peer to CUCM for 5 digit VOIP numbers?
Try this,
voice translation-rule 1
rule 1 /^02476012665/ /88000/
voice translation-profile CLI
translate called 1
then apply it to the dial-peer
dial-peer voice 20 voip
translation-profile outgoing CLI
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Brilliant, you are a star mate that works, I need to read more about voice translation. I was applying rules as incoming
I also tried to make outbound call which works only when Router Pattern is
0[1-7]XXXXXXXXXX and outgoing dial peer is matching destination-pattern 0[1-7].........
But I want to make call with 9 for example 91785830000 I changed Route Pattern  9[1-7]XXXXXXXXXX and configured Discard Digit None with following dial peers. But it fails I think I also need to apply 9 DIGIT Strip translation rule.
I have also tried this with destination-pattern 9T to strip digit without using translation rule but that doesn’t work either. Need your help please
dial-peer voice 2 voip
description *** Outbound calls to ITSP ***
destination-pattern 90[1-7].........
session protocol sipv2
session target sip-server
dtmf-relay rtp-nte
codec g711alaw
Yes you need to strip the 9. because your provider does not want the 9
You can do that from CUCM..
configure 9.0[1-7]XXXXXXXXXX and the do discard digits predot.
You then need to ensure your destination-pattern in the gateway does not have 9 inform of it because cucm will send the calls without 9
Hi Aok,
I tried that way 9.0[1-7]XXXXXXXXXX and the do discard digits predot but some reason this does not discard 9 and send it sends all digits with 9
From: <86860>;tag=2653607~867df168-c5c9-4b90-8b3a-75c7400ce77b-44046791
To: <901785830000>;tag=876B708-125D
However if I configure 91.0[1-7]XXXXXXXXXXX it or any other digit with apart from 9 it strip predot for example 77.0[1-7]XXXXXXXXXXX. Is that any BUG??? Can we strip digit through translation profile?
Route Pattern with 91.0[1-7]XXXXXXXXXXX
INVITE sip:01785830000@10.116.143.151:5060 SIP/2.0
Via: SIP/2.0/TCP 10.102.243.13:5060;branch=z9hG4bK8176776429784
From: <>;tag=2653934~867df168-c5c9-4b90-8b3a-75c7400ce77b-44047317
To: <01785830000>
Date: Wed, 27 Mar 2013 12:58:57 GMT
Route Pattern with 9.0[1-7]XXXXXXXXXX
INVITE sip:901785830000@10.116.143.151:5060 SIP/2.0
Via: SIP/2.0/TCP 10.102.243.13:5060;branch=z9hG4bK817f21e48fd6a
From: <86860>;tag=2654256~867df168-c5c9-4b90-8b3a-75c7400ce77b-44047797
To: <901785830000>
Date: Wed, 27 Mar 2013 13:03:01 GMT
I want the CUBE config. I dont htink there is a problem with CUCM.
UPDATED:
OK,
Thats strange..
Lets do this..
voice translation-rule 100
rule 1 /^9/ //
translation-profile STRIP9
translate called 100
dial-peer voice 101 voip
translation-profile incoming STRIP9
Hi Aok,
I tried this but still its not stripping the 9 number.
RoutePattern 9.0[1-7]XXXXXXXXXX and the Nodigits discard predot
I have attached CUBE config and CCSIP debug All logs
I updated the post to say that you should apply it to dial-peer 101
Yep that works Can you please suggest me docuementation about voice translation to understand how it works.
One Last thing currently ANIS is showing numbers starting with +4407XXXXXXXX (sip:+447967999481) which I want to replace with 9XXXXXXXXXX. I mean nation type, internation type.
Can you please help me what translation rule I will use for this and on which dial-peer it will apply?
Hi you can add this to the existing voic transaltion-rule 1
rule 2 /^+44\(...........\)/ /9\1/  ---------NB th enumber of dots should = to the number of digits after +44
translate calling 1
You can read more about translation rules here
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml
Hi Aok,
I am testing SIP calls, most of the tests are ok apart from two following issues
1) CLI display sometime and somtime doesn't
2) The time CLI display on the called handset (mobile phone) if I try to reject call from the called handset it disconnects on called handset (mobile phone) butI can hear VOIP handset still ringing which ends after couple of minutes.
I have treid to fix CLI by adding SIP profies but it doesn't work on the outgoind dial-peer to ITSP
voice class sip-profiles 1
request INVITE sip-header P-Asserted-Identity add "P-Asserted Identity:<02476012665>"
Muhammad,
1. CLI issues..What is the requirement? Do you need CLI displayed on all calls?
In what direction do you have CLI issues? Is it inbound calls or outbound calls
You need to do some test call and send  "debug ccsip messages" for scenarios where CLI is not displayed..I need to see what you are sending to your ITSP if it is affecting outbound calls
2. The second question is a know behaviour of SIP trunks. When you reject a call, it rings for a while on the phone before it terminates. We may be able to work on it..You can also do a test call and send "debug ccsip messages"
Hi Aok
  • •1) There is no CLI issues for inbound calls. Issue is for only outbound calls which display sometime on called number and sometime doesn’t. Don’t know is that ITSP issue or any configuration issue.
If outbound CLI display issue resolves then I want to display outbound CLI from specific VOIP numbers and block outgoing CLI for specific numbers.
  • •2) Call termination behaviour is quite weird, if outbound CLI display then call termination does not complete. However the time outbound CLI doesn’t display it terminates straightway.
Please see ccsip messages debug
