CUBE configuration with CUCM Call Manager
sarwarm123
Our company recently decided to have a SIP trunk in our Cisco VOIP environment. I have not configured CUBE router before so I have read number of documents related to CUBE configuration with CUCM. However I still have confusion so I need your help. Please see proposed network diagram below.
My Question is, do we connect one gig port to company LAN where CUCM is connected and second gig interface will connect to SIP Provider customer end router? For example
interface GigabitEthernet0/0
description Connection to LAN
ip address 172.102.243.10 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
description connection to SIP Provider
ip address 99.102.153.24 255.255.255.0
duplex auto
speed auto
I have seen some other sample configurations where people configured only one gig port for example (I have also attached full sample configuration)
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
no ip address
shutdown
duplex auto
speed auto
service-policy output VOIP-Policy
description $ES_LAN$
ip address 146.191.201.41 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 146.191.201.41
7 Accepted Solutions
Ayodeji Okanlawon
Atif,
Both solutions are correct. You can use a single interface or use two different interfaces..here is what you need to know
1. When you are using a single gig/fast thernet interface..You must ensure that your ITSP can route traffic to that internal IP address. Most people dont do this unless you can create a secure tunnel between this IP and your ITSP
2. Once you ensure your ITSP can reach this IP, you then bind your SIP signalling and  media traffic to this interface
3. If you are using a different IP to connect to your ITSP than your local LAN interface, then bind your sip traffic to the IP address facing your ITSP.
4. If you have multiple ITSP for redundancy purposes or load balancing, then you should configure your bind traffic under the dial-peer facing each provider.Example shown below
interface loopback1
ip address 10.10.10.1 255.255.255.0---------------------------------Service provider 1 IP
interface loopback2
ip address 20.20.20.1 255.255.255.0------------------------SP 2 IP
dial-peer voice 10 voip
description “Primary path to SIP SP-1”
destination-pattern 91[2-9]..[2-9]......
session protocol sipv2
session target ipv4:10.10.10.2
voice-class sip options-keepalive
voice-class sip bind control source-interface loopback1
voice-class sip bind media source-interface loopback1
dial-peer voice 20 voip
description “Secondary path to SIP SP-2”
session target ipv4:20.20.20.2
preference 2
voice-class sip bind control source-interface loopback2
voice-class sip bind media source-interface loopback2
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Muhammad,
Here are some thoughts for you
1. Configure CUBE for media flow through. In this Mode CUBE acts as a true B2BUA. Advantages you get include address hiding and security becaue CUBE terminates and re-originate both signalling and Media. In this mode CUBE becomes a point of demarcation from th external world.
2. Configure CUCM to use Delayed Offer and CUBE to convert delayed offer to ealry offer...This prevents the need for you to use MTP to send Early offer on CUCM
voice service voip
early-offer forced
3. Configure DTMF signalling method on sip trunk to "No preference" This setting allows Unified CM to make an optimal decision for DTMF and to minimize MTP allocation.
4. Configure your CUBE to meet the requirements of your ITSP. Ask if they have configuration templates or any specific configuration they like you to use. This will save you time troubleshooting. Most of them dont use the default port 5060 because of security, confirm with your proivider what ports they use.
voice service voip
allow-connections sip to sip
sip
early-offer forced
header-passing
error-passthru
5. Use SIP to SIP...Use end to end sip. CUCM---sip---CUBE--sip----ITSP
6. Create a Trusted list of IP addresses on your CUBE is your CUBE IOS is 15.1 .2(T) and above.
voice service voip
ip address trusted list
  ipv4 203.0.113.100 255.255.255.255
  ipv4 192.0.2.0 255.255.255.0
This is imprtant because sometimes your ITSP will send you a single ip address for signalling and will then send media on a different IP adress. So get all the IP address your ITSP is using and add them to the trust list as shown above
7. Configure your inbound and outbound dial-peer approriately
Inbound Dial-Peer for calls from CUCM to CUBE (CUCM sending 9 +all digits dialled to CUBE)
dial-peer voice 100 voip
description *** Inbound LAN side dial-peer ***
incoming called-number 9T
codec g711ulaw
dtmf-relay rtp-nte
Outbound Dial-Peer for calls from CUBE to CUCM (SP will be sending 10 digits inbound)
dial-peer voice 200 voip
description *** Outbound LAN side dial-peer ***
destination-pattern [2-9].........
codec g711ulaw
dtmf-relay rtp-nte
Note: If more than 1 CUCM cluster exists, you will have to create multiple such LAN dial-peers with “preference CLI” for CUCM redundancy/load balancing
Inbound Dial-Peer for calls from SP to CUBE
description *** Inbound WAN side dial-peer ***------------------(catch-all for all inbound PSTN calls)
incoming called-number [2-9].........
codec g711ulaw
dtmf-relay rtp-nte
Outbound Dial-Peer for calls from CUBE to SP
description *** Outbound WAN side dial-peer ***
translation-profile outgoing Digitstrip
destination-pattern 9[2-9].........
voice-class sip bind control source gig0/1
voice-class sip bind media source gig0/1
session target ipv4::XXXX (where XXXX is the port number your provider is using if different from 5060)
codec g711ulaw
dtmf-relay rtp-nte
8. SIP Normalization:
You may need to configure sip normnalization to modify sip headers, CLI etc. A good example is during call forwarding. You may need to change your diversion headers to  match the CLI your provider is expecting.. if your call forwarding is failing during testing this may be the reason..We can help you with this.
9. Media Resources
Plan your solution properly. Consider if you will need Xcoders, MTP, Conference bridge etc. You may avoid the need for xcoders if you confure your regions properly and use voice class codecs on your sip profiles. It is important to know if there are any endpoints in your network that do not support dtmf relay rtp-nte. You can avoid the use of MTP if you configure your dial-peers to have multiple dtmf types for thos phones that do not support rtp-nte
e.g
dial-peer voice 1 voip
dtmf-relay rtp-nte digit-drop sip-kpml (if your phones support kpml..then this will be used)
If in your environment you will need to do xcoding or CFB then ensure you have PVDMS
.10.FAX
If you have FAX in your network, determine what fax protocol your sip provider supports. Dont assume. Ask them and confirm in writing  what they support. I have seen legal cases because of fax failures over sip trunks
Configure your FAX devices in seperate device pools and use porefix to route calls using G711 only. Even if you are using T38, ensure your fax use G711 to establish the voice calls
Finally
11. Have a detailed and carefully planned TEST Plan. Test the FF:
  • Inbound and outbound Local, Long distance, International calls for G711 & G729 codecs (if supported by provider)
  • Outbound calls to information and emergency services
  • Caller ID and Calling Name Presentation
  • Supplementary services like Call Hold, Resume, Call Forward & Transfer
  • DTMF Tests
  • Fax calls – T.38, modem pass-through--whichever one you decide to use
Muhammad,
Your sip-server config has to point to the signalling address of your ITSP
sip-ua
sip-server ipv4:10.123.0.1 ( you dont need to speficy the port if they are using default 5060)
Then you will need to configure a static route to both signalling and media ip address via the ITSP gateway
ip route 10.123.0.1 255.255.255.255 10.160.134.97
ip route 10.123.0.2 255.255.255.255 10.160.134.97
Your sip trunk from CUCM should point to the LAN onterface on the CUBE, however if your CUCM can reach the WAN interface on the CUBE, then use this ip address on your sip trunk, then configure your sip signalling and media bind on this interface... This will give you the advantage of having your sip signalling and RTP flowing on one Interface of the CUBE
If you are going to use the LAN interface of CUBE for the SIP trunk from CUCM then I suggest you either dont configure any bind statements or bind on the WAN interface facing the ITSP
Glad I could help. You can just use voice translation rules to strip the 9. The destination pattern 9T should be pointing to your ITSP not CUCM..as you have on dial-peer 2. You can use 9T on dial-peer 2 also
Try this,
voice translation-rule 1
rule 1 /^02476012665/ /88000/
voice translation-profile CLI
translate called 1
then apply it to the dial-peer
translation-profile outgoing CLI
I updated the post to say that you should apply it to dial-peer 101
dial-peer voice 101 voip
translation-profile incoming STRIP9
Hi you can add this to the existing voic transaltion-rule 1
rule 2 /^+44\(...........\)/ /9\1/  ---------NB th enumber of dots should = to the number of digits after +44
translate calling 1
You can read more about translation rules here
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml
65 Replies 65
Ayodeji Okanlawon
Atif,
interface loopback1
interface loopback2
preference 2
Hi Aokanlawon,
Thanks mate to clear my concept much appreciate. As you know our company going to have SIP trunk, will you give my any tip or suggest best practices related to CUBE configuration with CUCM 8.6
Muhammad,
voice service voip
early-offer forced
voice service voip
sip
early-offer forced
header-passing
error-passthru
voice service voip
codec g711ulaw
dtmf-relay rtp-nte
codec g711ulaw
dtmf-relay rtp-nte
codec g711ulaw
dtmf-relay rtp-nte
codec g711ulaw
dtmf-relay rtp-nte
9. Media Resources
e.g
.10.FAX
Finally
  • DTMF Tests
Aokanlawon you are a star mate, these guidelines will be extremely helpful for me. I probably need your help for SIP Normalization script when I get to that stage. Once again thank you very much
Hi Aokanlawon,
I just received following network details from the ITSP. Please see my config below. Also, I have couple of questions related to the information I received from ITSP
  • sip-server ip address would be CUBE WAN (CUBE WAN/PBX IP 10.160.134.98) address or ITSP Gateway IP (10.160.134.97)?
  • Shall I route ip any to CUBE LAN or ITSP Gateway IP?
Details received from ITSP
Gateway IP: 10.160.134.97
PBX IP: 10.160.134.98
Signalling Address: 10.123.0.1
Media Access: 10.123.0.2
CUBE LAN: 10.116.143.2
CUBE WAN: PBX IP = 10.160.134.98
CUCM: 10.206.143.12
voice service voip
ipv4 10.160.134.96/29
ipv4 10.123.0.1 255.255.255.255
ipv4 10.123.0.2 255.255.255.255
ip route 0.0.0.0 0.0.0.0 10.116.143.1 //CUBE LAN network Default Gateway//
sip-ua
sip-server ipv4:10.160.134.97:5060 //ITSP Gateway IP address//
Message was edited by: Muhammad Atif Sarwar
Muhammad,
sip-ua
Many thanks Aokanlawon for your reply, so that means signalling address of the ITSP will also be used here
CUCM cannot reach the WAN interface of the CUBE because that ip addresses are given by ITSP.
Gateway IP: 10.160.134.97   //ITSP LAN interface of their Router//
PBX IP: 10.160.134.98         //CUBE WAN interface//
As you said if our SIP trunk from CUCM point to the LAN inferface on the CUBE then dont configure any bind statements so in that case I dont need to use bind statements the below dial-peer
session target ipv4:<10.123.0.1>:XXXX (where XXXX is the port number your provider is using if different from 5060)
codec g711ulaw
dtmf-relay rtp-nte dial-peer voice 200 voip
codec g711ulaw
dtmf-relay rtp-nte
I think you may have a translation profile that is prefixing the 9..
Send me your updated config
You need to apply sip profile 1 and not 2. You have configured profile 1, but applied 2 on the dial peer
Hi Aok,
I think it was writting mistake but just for the safe side I remvoed the sip profile from the dial-peer and added SIP PROFILE 1. But error is exactly same.
However I noticed in ccsip debug,
CLI works when VOIP number shows@10.60.34.98
CLI does not work when VOIP number points@10.116.143.151
Please see attached both debugs
voice class sip-profiles 1
request INVITE sip-header P-Asserted-Identity modify "<44043>" "<02476012665>"
dial-peer voice 2 voip
description *** Outbound calls to ITSP ***
destination-pattern 0[1-8].........
session target sip-server
voice-class codec 1
voice-class sip profiles 1
dtmf-relay rtp-nte
Hi Aok,
Issue has been resolved by modifled sip invite 44043 to 10.60.34.98 instead of 10.116.143.151. Can you please guide whats a syntax for range of numbers instead one fixed number. I mean not 44043 could be 44000 to 44150.
request INVITE sip-header P-Asserted-Identity modify "<44043>" "<44043>"
Also If you could guide me what translation rule would be for this senario
DDI 024760126XX changes to 5 digit VOIP number 526XX
Just like we do in num-exp
num-exp  0247601.... 526..
Currernt Rule is 02476012665 is translated to 44043
rule 1 /^02476012665/ /44043/
Ayodeji Okanlawon
Your session target will point to sip-server unless you want to use IP address, then yes it will be the signalling address.
Yes no need for bind statements on the dial-peer.
Sent from Cisco Technical Support Android App
Hi Aokanlawon,
Many thanks for your great help. I have ready sample  configuration for the CUBE router as per your guidelines. It would be  extremely helpful if you could have a quick look. I haven’t add  outgoing/incoming translation rules which I will add later.
I have also created SIP trunk from CUCM to CUBE, device pool, route pattern etc
I have two more questions
  • Can you please provide me SIP normalization sample code as ITSP expecting CLI all digits
  • To make SIP calls from cisco phones 7942/7965 do I need to convert it from SCCP to SIP by upgrading SIP firmware.
Current configuration : 5885 bytes
version 15.2
hostname CDC-CUBE
boot-start-marker
boot-end-marker
logging queue-limit 10000
logging buffered 20000000
logging persistent filesize 20000000
logging rate-limit 10000
no logging console
no aaa new-model
crypto pki trustpoint TP-self-signed-1280150379
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1280150379
revocation-check none
rsakeypair TP-self-signed-1280150379
crypto pki certificate chain TP-self-signed-1280150379
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31323830 31353033 3739301E 170D3133 30323034 30383138
  34395A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 32383031
  35303337 3930819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100C4A2 10C7A212 340E3076 D97FA3BD E66D091F D5926342 BE07DDA7 C3CE96D6
  5441E4E9 9F673426 09A4E71C 1C653F3E E582DB0D D7DFB19C 2C9D4FB9 2563F32F
  F4E87C2A D1504B65 5B751DF3 1432F665 DF6A96C0 72916968 E039D009 D63E957B
  650374B5 5202DCC3 1D152F55 062DE7A1 8EF30730 33CABCA9 D64850F5 988BAC7A
  EE4B0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 1456B52D 8E122C64 3BCBBA4A E67BAA04 F4DD76F7 A5301D06
  03551D0E 04160414 56B52D8E 122C643B CBBA4AE6 7BAA04F4 DD76F7A5 300D0609
  2A864886 F70D0101 05050003 818100C0 968CA8CD 5458E81D 93761550 23EF0AC1
  E97EE575 B9F5E8EF F69F39D4 CF3D688F EBB9DD9A 490F5109 5EE1A207 1EE73280
  AB89D93B 3FEA6FCA 3EC7B8E8 DF48B748 5998502B D6A7B6DB C4D33AF8 871953FB
  13387DDB 782C6695 DB5DC72D EC954FFB 96D86E78 B3997BF4 88E7C6D7 2134D8DD
  583C667F 6B67E1C4 8DD2DB1B E58A0E
        quit
ip cef
ip domain name cwss.nhs.uk
no ipv6 cef
voice-card 0
voice service voip
  ipv4 10.116.143.2 255.255.255.255
  ipv4 10.206.143.0 255.255.255.128
  ipv4 10.160.134.96 255.255.255.248
address-hiding
mode border-element
redirect ip2ip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  header-passing
  error-passthru
  asserted-id pai
  early-offer forced
  midcall-signaling passthru
  privacy-policy passthru
license udi pid CISCO2951/K9 sn FGL1706105K
hw-module pvdm 0/0
username admin privilege 15 secret 5 $1$yF52$HweSxAz.i8CWNbTjhXLgb.
redundancy
csdb tcp synwait-time 30
csdb tcp idle-time 3600
csdb tcp finwait-time 5
csdb tcp reassembly max-memory 1024
csdb tcp reassembly max-queue-length 16
csdb udp idle-time 30
csdb icmp idle-time 10
csdb session max-session 65535
interface Embedded-Service-Engine0/0
no ip address
shutdown
description CUBE WAN interface
ip address 10.160.134.98 255.255.255.248
duplex auto
speed auto
description CUBE LAN interface
ip address 10.116.143.2 255.255.255.192
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 10.123.0.1 255.255.255.255 10.160.134.98
ip route 10.123.0.2 255.255.255.255 10.160.134.98
nls resp-timeout 1
cpd cr-id 1
control-plane
mgcp profile default
dtmf-relay rtp-nte
codec g711ulaw
session target ipv4:10.206.143.13
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 21 voip
session target ipv4:10.206.143.12
dtmf-relay rtp-nte
codec g711ulaw
dtmf-relay rtp-nte
codec g711ulaw
session target ipv4:10.123.0.1
dtmf-relay rtp-nte
codec g711ulaw
sip-ua
no remote-party-id
disable-early-media 180
retry invite 2
gatekeeper
shutdown
line con 0
exec-timeout 30 0
privilege level 15
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
access-class 23 in
exec-timeout 15 0
privilege level 15
logging synchronous
login local
transport input telnet ssh
line vty 5 15
access-class 23 in
exec-timeout 30 0
privilege level 15
login local
scheduler allocate 20000 1000
ntp server 194.172.9.137
ntp server 194.172.9.142 prefer
end
CDC-CUBE#
It looks good. You might want to change the description on your dialpeers to reflect what they actually do..
eg
description ***Inbound calls from CUCM****
description **** Outbound calls to Primary CUCM ***
description *** Outbound Calls to Backup CUCM***
description *** Inbound Calls from ITSP ***
This description helps especially when you are troubleshooting..
I can certainly help you with sip normalization but I need to know what you want normalized.
ex
This sip profile modifies the remote party id of any number begining with 1234 to 441756789000
request INVITE sip-header Remote-Party-ID modify "<1234>" "<441756789000>
No, you dont need to ocnvert SCCP phones to SIP. SCCP phones can still send calls over the sip trunk.
I observed that in your sip-ua config you have "no remote-party id" is there any reason for this?
