02-19-2020 07:09 AM
Hi, I have the following environment where outgoing calls to external SIP telekom provider are failing.
Incoming calls from the ITSP are working perfectly.
CUCM => SIP trunk => CUBE => ITSP
The ITSP supports: G711A, G711U, G729a, G722.
My config is as follows:
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
codec preference 4 g722-64
voice class codec 2
codec preference 1 g729r8
codec preference 2 g729br8
codec preference 3 g711alaw
codec preference 4 g711ulaw
voice class codec 3
codec preference 1 g711ulaw
codec preference 2 g722-64
codec preference 4 g729r8
voice class codec 4
codec preference 2 g711alaw
codec preference 4 g729br8
dspfarm profile 1 transcode
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
codec g722-64
codec g729br8
codec g729r8
maximum sessions 16
associate application SCCP
dial-peer voice 100 voip
description *Incoming from ITSP*
translation-profile incoming INCOMING_FROM_ITSP
session protocol sipv2
session transport udp
incoming called-number 3........$
incoming uri via ITSP
voice-class codec 1
voice-class sip profiles 1000
dtmf-relay sip-notify rtp-nte
dial-peer voice 200 voip
description *Outgoing to CUCMs*
destination-pattern 4...$
session server-group 10000
voice-class codec 2
voice-class sip options-keepalive
voice-class sip bind control source-interface GigabitEthernet0/0/0.7
voice-class sip bind media source-interface GigabitEthernet0/0/0.7
dtmf-relay rtp-nte
dial-peer voice 300 voip
description *Outbound to ITSP*
translation-profile outgoing OUTGOING_TO_ITSP
session target sip-server
destination e164-pattern-map 2222
voice-class sip profiles 2000
codec g711alaw
no vad
dial-peer voice 400 voip
description *Incoming from CUCM*
incoming uri via CUCMs
dtmf-relay rtp-nte
no vad
And when I try an outgoing test call from one of the IP phones registered in the CUCM this is the debug I get (I´ve replaced the sensitive data with meaningful terms):
*Feb 19 12:45:16.109: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:Number2@CUBEs_Gi_IP:5060 SIP/2.0
Via: SIP/2.0/UDP CUCM_IP:5060;branch=z9hG4bK213b7562525ed
From: <sip:Number1@CUCM_IP>;tag=56087855~6a4d89ba-15e8-47e9-91bc-eed45860d755-63529998
To: <sip:Number2@CUBEs_Gi_IP>
Date: Wed, 19 Feb 2020 12:40:03 GMT
Call-ID: f1cf1900-e4d12ca3-1959c7-f904240a@CUCM_IP
Supported: timer,resource-priority,replaces
Min-SE: 1800
User-Agent: Cisco-CUCM10.5
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence, kpml
Supported: X-cisco-srtp-fallback
Supported: Geolocation
Call-Info: <sip:CUCM_IP:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Call-Info: <urn:x-cisco-remotecc:callinfo>;x-cisco-video-traffic-class=MIXED
Cisco-Guid: 4056881408-0000065536-0000006392-4177798154
Session-Expires: 1800
P-Asserted-Identity: <sip:Number1@CUCM_IP>
Remote-Party-ID: <sip:Number1@CUCM_IP>;party=calling;screen=yes;privacy=off
Contact: <sip:Number1@CUCM_IP:5060>
Max-Forwards: 68
Content-Type: application/sdp
Content-Length: 297
v=0
o=CiscoSystemsCCM-SIP 56087855 1 IN IP4 CUCM_IP
s=SIP Call
c=IN IP4 CUBEs_Gi_IP
b=TIAS:64000
b=AS:64
t=0 0
m=audio 8000 RTP/AVP 0 18 9 8 101
a=rtpmap:0 PCMU/8000
a=rtpmap:9 G722/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
*Feb 19 12:45:16.113: //4/F1CF19000000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 488 Not Acceptable Media
To: <sip:Number2@CUBEs_Gi_IP>;tag=42F18-195C
Date: Wed, 19 Feb 2020 12:45:16 GMT
CSeq: 101 INVITE
Allow-Events: telephone-event
Reason: Q.850;cause=65
Server: Cisco-SIPGateway/IOS-16.9.4
Session-ID: 1527fc57a8f45c5d9cf7f0fabf069885;remote=ac1dac794fdb5bb8a00b6e1236ade447
Content-Length: 0
*Feb 19 12:45:16.170: //4/F1CF19000000/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:Number2@CUBEs_Gi_IP:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
As I understand the phone is offering those codecs to the CUBE:
But CUCM and CUBE are having a codec mismatch somewhere, the call is not even sent to the ITSP yet.
Additional data:
- my trunk in CUCM is configured for early-offer;
- my trunk in CUCM does not rely on an MTP; already tried that with same result;
- my trunk in CUCM does rely on a transcoder configured in CUBE;
- g711a is hardcoded on the outgoing dial-peer facing ITSP, I tried changing that with no luck;
- I tried putting all different four codec profiles I´ve got in the incoming dial-peer facing CUCMs with no luck. Also tried changing codec order, tried forcing everything to work with g711a, no luck.
- I checked phone region with trunk region relationship and its set to talk with g711 and g722.
Can someone see what I´m missing?
thank you,
02-19-2020 11:21 AM
02-20-2020 04:32 AM
02-20-2020 08:21 AM
Did you see the part where OP claimed to have tried voice class codec 2 already? If that's true, then I wonder why it didn't work for them.
"I tried putting all different four codec profiles I´ve got in the incoming dial-peer facing CUCMs with no luck."
02-21-2020 01:39 AM
I did see that but maybe not really took it in. I still think that should have worked, but would like to see the debug. Maybe it worked at the CUBE but got knocked back by the ITSP.
