CUBE HA Can't enter redundancy-group 1 under voice service voip
VON CLAWSON
Level 3
Level 3
I'm configuring CUBE HA on 4461 routers. Smart licensing is enabled and authorized. Cube status is showing good
PHC-COLO-ISR-02#sh cube status
CUBE-Version : 12.7.0
SW-Version : 16.12.3, Platform ISR4461/K9
HA-Type : none
Licensed-Capacity : 400
Calls blocked (Smart Licensing Not Configured) : 0
Calls blocked (Smart Licensing Eval Expired) : 0
voice service voip
mode border-element license capacity 400
allow-connections sip to sip
no supplementary-service sip refer
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
no fax-relay sg3-to-g3
sip
session refresh
options-ping 60
midcall-signaling passthru
g729 annexb-all
sip-profiles inbound
sip-profiles 101
sip-profiles 100 inbound
no call service stop
redundancy
mode none
application redundancy
group 1
name CUBE-HA
priority 100 failover threshold 75
timers delay 30 reload 60
control Port-channel2 protocol 1
data Port-channel2
track 1 shutdown
track 2 shutdown
protocol 1
name Provider_RG
timers hellotime 4 holdtime 12
protocol 2
name Internal_RG
But when I try to enter the redundancy-group 1 under the voice service voip configuration I get this
PHC-COLO-ISR-02(conf-voi-serv)#redundancy-group 1
% Invalid input detected at '^' marker.
Here is my licenses
License Usage
ISR_4400_UnifiedCommunication (ISR_4400_UnifiedCommunication):
Description: Unified Communications License for Cisco ISR 4400 Series
Count: 1
Version: 1.0
Status: AUTHORIZED
Export status: NOT RESTRICTED
ISR_4400_Security (ISR_4400_Security):
Description: Security License for Cisco ISR 4400 Series
Count: 1
Version: 1.0
Status: AUTHORIZED
ISR_4400_Hsec (ISR_4400_Hsec):
Description: U.S. Export Restriction Compliance license for 4400 series
Count: 1
Version: 1.0
Status: AUTHORIZED
Export status: RESTRICTED - ALLOWED
Feature Name: hseck9
Feature Description: Export Controlled Feature hseck9
CUBE v12 Trunk Standard Session (CUBE_T_STD):
Description: Cisco Unified Border Element (CUBE) Trunk Standard Session
License
Count: 400
Version: 1.0
Status: OUT OF COMPLIANCE
Please rate if this helps.
Not sure if it’s related, but you’re not licensed for redundant trunk sessions.
“CUBE v12 Trunk Standard Session (CUBE_T_STD):
Description: Cisco Unified Border Element (CUBE) Trunk Standard Session”
You’ll need to have CUBE_T_RED for HA.
Response Signature
Yes, I knew that part. But will that stop me from being able to put in that command? Or is this a bug in this IOS?
Your guess is as good as mine. To really know you have a few options, a couple of them are listed below, there are likely others as well.
  • Upgrade or downgrade to another version to test your theory of a defect in your specific version
  • Open a SR with TAC to work with them to find out the cause of your problem
Response Signature
