CUBE HA with two or more sip-providers
Victor Elizarov
Is it real to configure two sip providers on CUBE HA (active-standby) model?
Chris Deren
Sure, I have few customer with such deployment, you will just need to identify and route (via dial-peers) which calls go to which provider.
+5 to Chris for his usual great suggestions
In addition to that, you can also server group feature that allows you to create multiple destinations in a group and point that group in a single dialpeer .
Here is a reference doc
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/dialpeer/configuration/15-mt/vd-15-mt-book/multiple-server-groups.pdf
Carlo
Please rate all helpful posts "The more you help the more you learn"
Dennis Mink
talking about HA for a call from CUCM to external; use a RG with top down, containing both CUBES.
Incoming calls from external:  use preferences on your dial peers and always use OOB pings to allow status checking on your dial peers, allowing automated fail over.
Please remember to rate useful posts, by clicking on the stars below.
