CUBE HSRP
Sean McQuade
Level 5
Level 5
Hi, has anybody implemented HSRP with a CUBE pair?
CUBE 1 is .1 and CUBE 2 is .2, HSRP is .3
Calls ingress from the ITSP to the public IP, natted to .3 but the CUBE tries to reply with .1 instead of the HSRP address.
Is it possible to implement HSRP in this manner?
Sean
Wilson Samuel
Level 7
Level 7
Hi Sean,
Here is a document you can refer to, please let us know if you have any further queries
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-border-element/112095-cube-hsrp-config-00.html
Jaime Valencia
There's a doc on CUBE redundancy with HSRP on cisco.com, have you reviewed it???
java
if this helps, please rate
Wilson Samuel
Level 7
Level 7
Hi Sean,
Sean McQuade
Level 5
Level 5
Hi guys, thanks for your responses. I had reviewed the doc and configured the CUBEs as per the doc, but it seems that HSRP CUBE just wouldn't work in our specific scenario due to the infrastructure in place. We raised a service request and had Cisco review the configuration, and they have advised us not to use it in our case.
Thanks for the update.
Glad I was able to help.
