Check on CUCM under route pattern config if Calling Line ID Presentation is restricted.
See the debugs if you are sending the ANI using the debug voice ccap inout
Use this link to see how to collect properly the debugs on a Cisco router.
https://supportforums.cisco.com/document/62906/how-properly-and-safely-collect-debugs-ios-router
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
